Ich bekomme nach dem Ausführen von Openems Backend folgende Fehlermeldung:
log4j] DEBUG : Trying to find [log4j.properties] using org.ops4j.pax.logging.pax-logging-log4j1/2.0.5 bundle.
Sep 28 09:08:27 raspberrypi java[1598]: org.ops4j.pax.logging.pax-logging-log4j1 [log4j] DEBUG : Trying to find [log4j.properties] using org.eclipse.osgi.internal.loader.EquinoxClassLoader@18bdf1f[org.ops4j.pax.logging.pax-logging-log4j1:2.0.5(id=41)] class loader.
Sep 28 09:08:27 raspberrypi java[1598]: org.ops4j.pax.logging.pax-logging-log4j1 [log4j] DEBUG : Trying to find [log4j.properties] using ClassLoader.getSystemResource().
Sep 28 09:08:27 raspberrypi java[1598]: org.ops4j.pax.logging.pax-logging-log4j1 [log4j] DEBUG : Could not find resource: [null].
Sep 28 09:08:27 raspberrypi java[1598]: org.ops4j.pax.logging.pax-logging-log4j1 [log4j] DEBUG : Parsing for [root] with value=[DEBUG, A1].
Sep 28 09:08:27 raspberrypi java[1598]: org.ops4j.pax.logging.pax-logging-log4j1 [log4j] DEBUG : Level token is [DEBUG].
Sep 28 09:08:27 raspberrypi java[1598]: org.ops4j.pax.logging.pax-logging-log4j1 [log4j] DEBUG : Category root set to DEBUG
Sep 28 09:08:27 raspberrypi java[1598]: org.ops4j.pax.logging.pax-logging-log4j1 [log4j] DEBUG : Parsing appender named “A1”.
Sep 28 09:08:27 raspberrypi java[1598]: org.ops4j.pax.logging.pax-logging-log4j1 [log4j] DEBUG : Parsing layout options for “A1”.
Sep 28 09:08:27 raspberrypi java[1598]: org.ops4j.pax.logging.pax-logging-log4j1 [log4j] DEBUG : End of parsing for “A1”.
Sep 28 09:08:27 raspberrypi java[1598]: org.ops4j.pax.logging.pax-logging-log4j1 [log4j] DEBUG : Parsed “A1” options.
Sep 28 09:08:27 raspberrypi java[1598]: org.ops4j.pax.logging.pax-logging-log4j1 [log4j] DEBUG : Finished configuring.
Ich habe zuvor an unseren Raspberry eine externe Festplatte gemountet.
openems-backend und backend.d befinden sich auf der Festplatte die Service Datei weiterhin auf der SD-Karte.
