Hello again!
Thanks for the reply as always. After some time of planning and understanding openEMS, we decided for our thesis work to use something similar to the “gridoptimizedcharge” controller that you shared previously, maybe adding other optimization parameters like “priorities” of usage e.g. if we have different sources of production (wind, PV or even diesel generator) which one should take priority for consumption or charging. I still need to think about how is it going to be, do you think this approach makes sense?
And here it comes another question, I’ve been able to implement new controllers and meters from what there is already in openEMS, but now I would like to simulate, as said before, more production devices and also storage. I understand that in the UI we see the sum of all the production and the ess as a whole, what should I do to be able to see them separately? For example, below I edited a screenshot:
