Hello erik40021, your activate()
method calls super.activate(..., config.enabled())
. Does the OsgiValidateWorker
warning always appear or only if your component is disabled?
What happens if you switch the enabled
state of your OSGI configuration?
Because I think the OsgiValidateWorker
will show this warning when a component is configured but not enabled.
What I do not understand is, why it should work if you implement Controller
