# How to install openEMS production ready?
**URL:** <https://community.openems.io/t/how-to-install-openems-production-ready/607>\
**Category:** English Forum\
**Created:** [September 4, 2021, 8:57pm UTC](https://community.openems.io/t/how-to-install-openems-production-ready/607 "2021-09-04T20:57:39Z")\
**Showing post:** 21
**Author:** ![stefan.feilmeier](https://community.openems.io/user_avatar/community.openems.io/stefan.feilmeier/32/2585_2.png) [@stefan.feilmeier](https://community.openems.io/u/stefan.feilmeier)\
**Post date:** [January 2, 2024, 3:14pm UTC](https://community.openems.io/t/how-to-install-openems-production-ready/607/21 "2024-01-02T15:14:56Z")
Hi @SvenAarts and welcome to the OpenEMS Community.
So many questions here… would have probably been better to open a new thread.
In general I do recommend following the Getting Started Guide ([Getting Started :: Open Energy Management System](https://openems.github.io/openems.io/openems/latest/gettingstarted.html)). Once that works including Edge and UI, you can start replacing the simulated components with real ones.
In your case it sounds like you are deploying Edge and UI to a separate computer (e.g. a Raspberry Pi). Be aware that in this case you should build the UI with `ng build -c "openems,openems-edge-prod,prod"`, adjusting the environment file if required ([https://github.com/OpenEMS/openems/blob/develop/ui/src/themes/openems/environments/edge-prod.ts](https://github.com/OpenEMS/openems/blob/develop/ui/src/themes/openems/environments/edge-prod.ts)).
You will also have to configure a webserver like NGINX and configure it for Angular applications. See → [UI am Raspberry konfigurieren](https://community.openems.io/t/ui-am-raspberry-konfigurieren/72)
_[View the full topic](https://community.openems.io/t/how-to-install-openems-production-ready/607)._
