I am trying to follow the procedure described in implement a device online guide from openEMS website:
Implementing a device :: Open Energy Management System (openems.github.io)
At step 1.6 Enable the Component when I clicked on Resolve to update the list of bundles that are required to run OpenEMS Edge although
bnd.identity;id=‘io.openems.edge.meter.simulated’ appeared I had to add manually
io.openems.edge.meter.simulated;version=’[1.0.0,1.0.1)’,\
Note: On Resolution Results there is no finish but rather update.
Now on step 1.7 Run the implementation I ran OSGi and from Apache Felix Web Console I set the corresponding settings to the Apache Felix Web Console but there is no Meter Simulated subsection. For this purpose I randomly chose Meter Weidmueller 525. The results from Eclipse IDE console are shown below:
2022-03-03T11:08:49,255 [re.Cycle] WARN [ms.edge.core.cycle.CycleWorker] [_cycle] Error in Controller [ctrlBalancing0]: Value for Channel [meter0/ActivePower] is invalid.
2022-03-03T11:08:49,255 [Worker-0] WARN [socket.AbstractWebsocketClient] Unable to send JSON-RPC message. WebsocketNotConnectedException: {“jsonrpc”:“2.0”,“method”:“timestampedData”,“params”:{}}
2022-03-03T11:08:49,255 [Backend0] INFO [socket.ClientReconnectorWorker] [ctrlBackend0] Waiting till next WebSocket reconnect [32s]
2022-03-03T11:08:49,255 [re.Cycle] INFO [ntroller.debuglog.DebugLogImpl] [ctrlDebugLog0] _sum[State:Fault Ess SoC:49 %|L:0 W Grid:1156 W Consumption:1156 W] ctrlBackend0[State:WARNING: UnableToSend] ctrlBalancing0[State:FAULT: Running the Controller failed] ess0[SoC:49 %|L:0 W] meter0[L:UNDEFINED|State:FAULT: Modbus Communication failed] meter0[1156 W]
2022-03-03T11:08:50,217 [modbus0 ] WARN [bridge.modbus.api.ModbusWorker] [modbus0] FC3ReadHoldingRegisters [meter0;unitid=1;ref=19000/0x4a38;length=122] execution failed: Transaction failed: Illegal Data Address: Illegal Data Address
2022-03-03T11:08:50,264 [re.Cycle]
Could you please help me debug the project and solve the modbus communication issue with the virtual smart meter?
For any further clarification feel free to contact me here.
