ich habe heute OpenEMS untergeladen und versucht zu nutzen. Ich benutze Java SE 8 und Eclipse IDE 2019-12. Bei “Run OpenEMS Edge and start Simulator” gibt es folgende Fehlermeldung in Output Console, deswegen kann ich keine localhost:8080 Webseite eröffnen:
org.ops4j.pax.logging.pax-logging-log4j1 [org.ops4j.pax.logging.spi.support.EventAdminConfigurationNotifier] INFO : Logging configuration changed. (Event Admin service unavailable - no notification sent).
io.openems.edge.application [io.openems.edge.application.EdgeApp] INFO : ===========================================
io.openems.edge.application [io.openems.edge.application.EdgeApp] INFO : OpenEMS version [2021.7.0-SNAPSHOT] started
io.openems.edge.common [io.openems.edge.common.component.AbstractOpenemsComponent] INFO : [_meta] Activate Core.Meta
io.openems.edge.common [io.openems.edge.common.component.AbstractOpenemsComponent] INFO : [_power] Activate Ess.Power
io.openems.edge.common [io.openems.edge.common.component.AbstractOpenemsComponent] INFO : [_evcsSlowPowerIncreaseFilter] Activate Evcs.SlowPowerIncreaseFilter
io.openems.edge.common [io.openems.edge.common.component.AbstractOpenemsComponent] INFO : [_host] Activate Core.Host
org.ops4j.pax.logging.pax-logging-log4j1 [org.ops4j.pax.logging.spi.support.EventAdminConfigurationNotifier] INFO : Sending Event Admin notification (configuration successful) to org/ops4j/pax/logging/Configuration
org.apache.felix.http.jetty [org.eclipse.jetty.util.log] INFO : Logging initialized @3595ms to org.eclipse.jetty.util.log.Slf4jLog
org.apache.felix.http.jetty [org.eclipse.jetty.server.Server] INFO : jetty-9.4.38.v20210224; built: 2021-02-24T20:25:07.675Z; git: 288f3cc74549e8a913bf363250b0744f2695b8e6; jvm 1.8.0_281-b09
org.apache.felix.http.jetty [org.eclipse.jetty.server.session] INFO : DefaultSessionIdManager workerName=node0
org.apache.felix.http.jetty [org.eclipse.jetty.server.session] INFO : No SessionScavenger set, using defaults
org.apache.felix.http.jetty [org.eclipse.jetty.server.session] INFO : node0 Scavenging every 660000ms
org.apache.felix.http.jetty [org.eclipse.jetty.server.handler.ContextHandler] INFO : Started o.e.j.s.ServletContextHandler@1aaccbcf{/,null,AVAILABLE}
org.apache.felix.http.jetty [org.eclipse.jetty.server.Server] INFO : Started @3746ms
org.apache.felix.http.jetty [org.eclipse.jetty.server.AbstractConnector] INFO : Started ServerConnector@29c34596{HTTP/1.1, (http/1.1)}{0.0.0.0:8080}
2021-04-06 14:55:13,469 [824c0a6b] INFO [org.apache.felix.http.jetty ] Started Jetty 9.4.38.v20210224 at port(s) HTTP:8080 on context path / [minThreads=8,maxThreads=200,acceptors=1,selectors=4]
2021-04-06 14:55:14,123 [824c0a6b] WARN [ntmanager.ComponentManagerImpl] bundle io.openems.edge.core:1.0.0.202104061245 (69)[io.openems.edge.core.componentmanager.ComponentManagerImpl(2)] : Could not get service from ref {io.openems.edge.common.component.ComponentManager, io.openems.edge.common.component.OpenemsComponent, io.openems.edge.common.jsonapi.JsonApi, org.osgi.service.cm.ConfigurationListener}={enabled=true, enabledComponents.target=(&(enabled=true)(!(service.factoryPid=Core.ComponentManager))), service.id=63, service.bundleid=69, service.scope=bundle, allComponents.target=(!(service.factoryPid=Core.ComponentManager)), id=_componentManager, component.name=Core.ComponentManager, component.id=2}
2021-04-06 14:55:14,126 [824c0a6b] ERROR [ROOT ] bundle org.apache.felix.scr:2.1.26 (151) Circular reference detected trying to get service {io.openems.edge.predictor.api.manager.PredictorManager, io.openems.edge.common.component.OpenemsComponent, io.openems.edge.common.jsonapi.JsonApi}={enabled=true, service.id=64, predictors.target=(enabled=true), service.bundleid=69, service.scope=bundle, id=_predictorManager, component.name=Core.PredictorManager, component.id=6}
stack of references: ServiceReference: {io.openems.edge.predictor.api.manager.PredictorManager, io.openems.edge.common.component.OpenemsComponent, io.openems.edge.common.jsonapi.JsonApi}={enabled=true, service.id=64, predictors.target=(enabled=true), service.bundleid=69, service.scope=bundle, id=_predictorManager, component.name=Core.PredictorManager, component.id=6}
ServiceReference: {io.openems.edge.common.component.ComponentManager, io.openems.edge.common.component.OpenemsComponent, io.openems.edge.common.jsonapi.JsonApi, org.osgi.service.cm.ConfigurationListener}={enabled=true, enabledComponents.target=(&(enabled=true)(!(service.factoryPid=Core.ComponentManager))), service.id=63, service.bundleid=69, service.scope=bundle, allComponents.target=(!(service.factoryPid=Core.ComponentManager)), id=_componentManager, component.name=Core.ComponentManager, component.id=2}
java.lang.Exception: stack trace
** at org.apache.felix.scr.impl.ComponentRegistry.enterCreate(ComponentRegistry.java:493)**
** at org.apache.felix.scr.impl.BundleComponentActivator.enterCreate(BundleComponentActivator.java:717)**
** at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:899)**
** at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:216)**
** at java.security.AccessController.doPrivileged(Native Method)**
** at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:213)**
** at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:114)**
** at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:48)**
** at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:547)**
** at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:533)**
** at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:656)**
** at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:88)**
** at org.apache.felix.scr.impl.inject.field.FieldHandler$ReferenceMethodImpl.getServiceObject(FieldHandler.java:525)**
** at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2556)**
** at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.prebind(DependencyManager.java:431)**
** at org.apache.felix.scr.impl.manager.DependencyManager.prebind(DependencyManager.java:1827)**
** at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1057)**
** at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:953)**
** at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:918)**
** at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.prebind(DependencyManager.java:1398)**
** at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:776)**
** at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1271)**
** at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1222)**
** at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1200)**
** at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1121)**
** at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:928)**
** at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:864)**
** at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1152)**
** at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:114)**
** at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:120)**
** at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:957)**
** at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)**
** at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)**
** at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:936)**
** at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:873)**
** at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:141)**
** at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:261)**
** at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:496)**
** at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:929)**
** at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:915)**
** at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133)**
** at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:984)**
** at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:752)**
** at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:515)**
** at org.apache.felix.metatype.internal.Activator.start(Activator.java:108)**
** at org.eclipse.osgi.internal.framework.BundleContextImpl$2.run(BundleContextImpl.java:814)**
** at org.eclipse.osgi.internal.framework.BundleContextImpl$2.run(BundleContextImpl.java:1)**
** at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:806)**
** at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:763)**
** at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1012)**
** at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:366)**
** at org.eclipse.osgi.container.Module.doStart(Module.java:605)**
** at org.eclipse.osgi.container.Module.start(Module.java:468)**
** at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1845)**
** at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136)**
** at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1838)**
** at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1781)**
** at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1743)**
** at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1665)**
** at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)**
** at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345)**
2021-04-06 14:55:14,131 [824c0a6b] WARN [ntmanager.ComponentManagerImpl] bundle io.openems.edge.core:1.0.0.202104061245 (69)[io.openems.edge.core.componentmanager.ComponentManagerImpl(2)] : Could not get service from ref {io.openems.edge.predictor.api.manager.PredictorManager, io.openems.edge.common.component.OpenemsComponent, io.openems.edge.common.jsonapi.JsonApi}={enabled=true, service.id=64, predictors.target=(enabled=true), service.bundleid=69, service.scope=bundle, id=_predictorManager, component.name=Core.PredictorManager, component.id=6}
2021-04-06 14:55:14,133 [824c0a6b] WARN [ntmanager.ComponentManagerImpl] bundle io.openems.edge.core:1.0.0.202104061245 (69)[io.openems.edge.core.componentmanager.ComponentManagerImpl(2)] : Could not get service from ref {io.openems.edge.common.component.ComponentManager, io.openems.edge.common.component.OpenemsComponent, io.openems.edge.common.jsonapi.JsonApi, org.osgi.service.cm.ConfigurationListener}={enabled=true, enabledComponents.target=(&(enabled=true)(!(service.factoryPid=Core.ComponentManager))), service.id=63, service.bundleid=69, service.scope=bundle, allComponents.target=(!(service.factoryPid=Core.ComponentManager)), id=_componentManager, component.name=Core.ComponentManager, component.id=2}
2021-04-06 14:55:14,134 [824c0a6b] ERROR [ROOT ] bundle org.apache.felix.scr:2.1.26 (151) Circular reference detected trying to get service {io.openems.edge.predictor.api.manager.PredictorManager, io.openems.edge.common.component.OpenemsComponent, io.openems.edge.common.jsonapi.JsonApi}={enabled=true, service.id=64, predictors.target=(enabled=true), service.bundleid=69, service.scope=bundle, id=_predictorManager, component.name=Core.PredictorManager, component.id=6}
Dependency: DependencyManager: Component [Component: Core.ComponentManager (2)] reference [allComponents]
2021-04-06 14:55:14,136 [824c0a6b] WARN [ntmanager.ComponentManagerImpl] bundle io.openems.edge.core:1.0.0.202104061245 (69)[io.openems.edge.core.componentmanager.ComponentManagerImpl(2)] : Could not get service from ref {io.openems.edge.predictor.api.manager.PredictorManager, io.openems.edge.common.component.OpenemsComponent, io.openems.edge.common.jsonapi.JsonApi}={enabled=true, service.id=64, predictors.target=(enabled=true), service.bundleid=69, service.scope=bundle, id=_predictorManager, component.name=Core.PredictorManager, component.id=6}
io.openems.edge.common [io.openems.edge.common.component.AbstractOpenemsComponent] INFO : [_componentManager] Activate Core.ComponentManager
io.openems.edge.common [io.openems.edge.common.component.AbstractOpenemsComponent] INFO : [_predictorManager] Activate Core.PredictorManager
io.openems.edge.common [io.openems.edge.common.component.AbstractOpenemsComponent] INFO : [_sum] Activate Core.Sum
io.openems.edge.common [io.openems.edge.common.component.AbstractOpenemsComponent] INFO : [_cycle] Activate Core.Cycle
2021-04-06 14:55:14,302 [824c0a6b] INFO [pax.logging.internal.Activator] Enabling Java Util Logging API support.
2021-04-06 14:55:14,302 [824c0a6b] INFO [pax.logging.internal.Activator] Enabling SLF4J API support.
2021-04-06 14:55:14,305 [824c0a6b] INFO [pax.logging.internal.Activator] Enabling Apache Commons Logging API support.
2021-04-06 14:55:14,307 [824c0a6b] INFO [pax.logging.internal.Activator] Enabling JULI Logger API support.
2021-04-06 14:55:14,308 [824c0a6b] INFO [pax.logging.internal.Activator] Enabling Avalon Logger API support.
2021-04-06 14:55:14,314 [824c0a6b] INFO [pax.logging.internal.Activator] Enabling JBoss Logging API support.
2021-04-06 14:55:14,316 [824c0a6b] INFO [pax.logging.internal.Activator] Enabling Log4J v1 API support.
2021-04-06 14:55:14,347 [824c0a6b] INFO [pax.logging.internal.Activator] Enabling Log4J v2 API support.
2021-04-06 14:55:15,193 [re.Cycle] WARN [ms.edge.core.cycle.CycleWorker] [_cycle] There are no Schedulers configured!
2021-04-06 14:55:16,176 [re.Cycle] WARN [ms.edge.core.cycle.CycleWorker] [_cycle] There are no Schedulers configured!
2021-04-06 14:55:17,178 [re.Cycle] WARN [ms.edge.core.cycle.CycleWorker] [_cycle] There are no Schedulers configured!
Ich habeProbleme bei Erstinstallation durch Anfänger mehr mal durchgelesen. Leider finde ich keine entsprechende Lösung. Mein Problem legt noch bei 3.1. Obwohl ich sehe Meldung “There are no Schedulers configured” in Output Console von Eclipse IDE. Aber vor diese Meldung gibt es Exception Info. Ich kann bei 3.2a keine Apache Felix Web Console Configuration eröffnen URL http://localhost:8080/system/console/configMgr geht nicht.
https://felix.apache.org/documentation
You have to start Apache Felix first from a terminal, After that works you can start the web-App on localhost. If you allready use port 8080 like me, you have to edit the config file in Apache-Felix and change there port 8080 to any like 8888 or such. Than restart apache Felix in the terminal again and try to get access to the webApp http://localhost:8888/system/console/configMgr
Also this may help: felix-dev/configadmin-plugins/interpolation at master · apache/felix-dev · GitHub
Anyhow, I have problems with the webApp because I can not see any configuration file and I am still trying to solve the problem.
Good luck!
ich habe heute neue Release von OpenEMS aus GitHub untergeladen. Dann gibt es bei Start von Edge.Application keine Exception mehr. Es scheint, dass ein Bug in früher Version gibt. Mit Chrome kann ich leider URL http://localhost:8080/system/console/configMgr nicht eröffnen. Mit Firefox geht es. Jetzt kann ich OpenEMS weiter kennenlernen.
Edit: I got the solution. at 2.e one has to define a minimum and maximum power, even though there is none in the tutorial.
Hi, i am currently trying to get the simulator to start, too. I ran into some problems at 2.e - GridMeter Acting. i get the following console output:
2021-05-27 15:05:46,690 [re.Cycle] INFO [ntroller.debuglog.DebugLogImpl] [ctrlDebugLog0] _componentManager[Defective:meter0[Failed activation java.lang.IllegalArgumentException: Unable to set value [] for Channel [meter0/_PropertyMinActivePower]: For input string: “”]] _sum[State:Ok]
2021-05-27 15:05:47,689 [re.Cycle] ERROR [or.meter.grid.acting.GridMeter] bundle io.openems.edge.simulator:1.0.0.202105261307 (132)[Simulator.GridMeter.Acting(15)] : The activate method has thrown an exception
at io.openems.edge.common.channel.Channel.setNextValue(Channel.java:109)
at io.openems.edge.common.component.AbstractOpenemsComponent.addChannelsForProperties(AbstractOpenemsComponent.java:319)
at io.openems.edge.common.component.AbstractOpenemsComponent.addChannelsForProperties(AbstractOpenemsComponent.java:260)
at io.openems.edge.common.component.AbstractOpenemsComponent.updateContext(AbstractOpenemsComponent.java:225)
at io.openems.edge.common.component.AbstractOpenemsComponent.activate(AbstractOpenemsComponent.java:140)
at io.openems.edge.simulator.meter.grid.acting.GridMeter.activate(GridMeter.java:86)
at jdk.internal.reflect.GeneratedMethodAccessor6.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:242)
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41)
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:678)
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:524)
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:318)
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:308)
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:342)
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:115)
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:984)
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:957)
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:902)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:312)
at org.apache.felix.eventadmin.impl.handler.EventHandlerProxy.obtain(EventHandlerProxy.java:295)
at org.apache.felix.eventadmin.impl.handler.EventHandlerProxy.sendEvent(EventHandlerProxy.java:423)
at org.apache.felix.eventadmin.impl.tasks.HandlerTask.runWithoutDenylistTiming(HandlerTask.java:82)
at org.apache.felix.eventadmin.impl.tasks.SyncDeliverTasks.execute(SyncDeliverTasks.java:107)
at org.apache.felix.eventadmin.impl.handler.EventAdminImpl.sendEvent(EventAdminImpl.java:155)
at org.apache.felix.eventadmin.impl.security.EventAdminSecurityDecorator.sendEvent(EventAdminSecurityDecorator.java:96)
at io.openems.edge.core.cycle.CycleWorker.forever(CycleWorker.java:52)
at io.openems.common.worker.AbstractWorker$1.run(AbstractWorker.java:112)
Caused by: java.lang.NumberFormatException: For input string: “”
at java.base/java.lang.NumberFormatException.forInputString(NumberFormatException.java:68)
at java.base/java.lang.Integer.parseInt(Integer.java:662)
at java.base/java.lang.Integer.parseInt(Integer.java:770)
at io.openems.edge.common.type.TypeUtils.getAsType(TypeUtils.java:165)
at io.openems.edge.common.channel.Channel.setNextValue(Channel.java:107)
… 35 more
Eclipse: Version: 2021-03 (4.19.0)
JavaSE - 1.8
at 2.c I get the console output
2021-05-27 15:17:31,104 [e7a9e99)] INFO [onent.AbstractOpenemsComponent] [ctrlDebugLog0] Activate Controller.Debug.Log
2021-05-27 15:17:31,410 [re.Cycle] INFO [ntroller.debuglog.DebugLogImpl] [ctrlDebugLog0] _sum[State:Ok], not the output shown in the tutorial.
Any ideas what I did wrong (or not)?
Thanks in advance!
