Dear All,
I just created a component that takes values from the simulated API that’s on my localhost and puts them into channels. On the backend side, they are sitting in the channels and I’m able to retrieve them using API REST/JSON component.
The problem is on the frontend side though. I created a new angular component following the pattern, I imported it, and as a result, I’m unable to pull the values from the channels since they are nulls, and it’s because in the frontend side the componentId seems to be “undefined”, as you can see on the following images.
The only configuration that I’ve done in the Web Console was turning on the Example component.
Can anybody help me to identify the root of this issue? Why the componentId is undefined?
For reference, here is my implementation.
The component in Java can be found here:
Next, I wrote a UI component, following the template. You can see it here:
Best regards everybody and thank you!
Karolina
