We’re facing an issue I cannot understand completely. At the history the graph with consumption and feed to grid looks plausible to me on first glance. But the value of feed to grid in the legend below the graph seems unreasonable large. Additionally the label for consumption seem to show a wrong sign (in my understanding the consumption should be positive). Cf. below screenshot.
Is this potentially a bug? Or could it be a configuration mistake? How can we debug it further? Thx for any support!
We are running OpenEMS 2026.11.0 Edge as docker.
Hi.
To help you in the right way, which smartmeter do you use?
First you should test, turn off all power generating devices such as pv and battery, what does the consumption then shows?
Then click on the gridsymbol in the overview, there it shows you what the meter reads on each phase, so you can see if there is consumption or feed to grid.
You also could configure a ctrDetailedLog as component add your meter. Then you can see detailed values in the log.
Thanks for your reply!
A Victron Grid Meter was configured. I now disabled the component and activated a Fronius Meter instead. I’ll report back, if that makes any change.
As a complete village is concerned (covering 15 PV inverters), that’s easier said than done.
But if changing the grid meter is not making any change, I’ll coordinate with the respective people and progress further in this direction.
hi.
maybe you can have a look in the evening, maybe there should be some consumption. With no minus sign.
After letting the system run a day with the Fronius grid meter, the numbers in OpenEMS look good. Thus I assume it’s a problem with the Victron Grid Meter component. I’m not sure if it was a configuration issue in our end, or if it is a bug in the component. Would be interesting to know, if the Victron component works for other people and where there might be a difference in the configuration.
