A Singleton Component for PID [Ess.Power] is already existing!
Can you please describe your issue more precise?
Thank you in advance.
I post json file for simulatorapp but tell me ā€œUnable to get Response: A Singleton Component for PID [Ess.Power] is already existing!ā€
What are you trying to do?
What you posted is clear for sure…
i try Request JSON-RPC. And in console :
… if somebody else is willing to look into the magic glass bowl go for it… i dont know what you are trying to do
It is indeed not very clear what you are trying to do. All I can say is that there is a singleton component with PID ā€œEss.Powerā€ and Component-ID ā€œ_powerā€, which is automatically activated. Maybe, from the error message, you are tring to activate a second one?
We can’t see your full Json-RPC request in the picture, it would help if we can fully see it.
I have the same problem, trying to follow the instructions for creating a simulator App at openems/io.openems.edge.simulator/readme.adoc at develop Ā· OpenEMS/openems Ā· GitHub but it seems this Ess.Power with id _power is created on run.EdgeApp. But I haven’t specified any Ess.Power in my JsonRPC so I guess that the _simulator tries to create a new one, but fails due to there already being one.
2024-05-30T13:19:13,535 [4573-145] INFO  [ontroller.api.rest.RestHandler] [ctrlApiRest0] REST/JsonRpc call by User [Admin]: {"method":"componentJsonApi","params":{"componentId":"_simulator","payload":{"method":"executeSim...
2024-05-30T13:19:13,535 [4573-145] INFO  [simulator.app.SimulatorAppImpl] [_simulator] Starting Simulation
2024-05-30T13:19:13,535 [4573-145] INFO  [simulator.app.SimulatorAppImpl] [_simulator] Delete Component [_evcsSlowPowerIncreaseFilter]
2024-05-30T13:19:13,540 [4573-145] INFO  [simulator.app.SimulatorAppImpl] [_simulator] Delete Component [_power]
2024-05-30T13:19:13,542 [eFilter)] INFO  [onent.AbstractOpenemsComponent] [_evcsSlowPowerIncreaseFilter] Modified Evcs.SlowPowerIncreaseFilter
2024-05-30T13:19:13,586 [eFilter)] INFO  [onent.AbstractOpenemsComponent] [_evcsSlowPowerIncreaseFilter] Modified Evcs.SlowPowerIncreaseFilter
2024-05-30T13:19:13,591 [s.Power)] INFO  [onent.AbstractOpenemsComponent] [_power] Modified Ess.Power
2024-05-30T13:19:13,594 [4573-145] INFO  [simulator.app.SimulatorAppImpl] [_simulator] All Components are deactivated!
2024-05-30T13:19:13,629 [s.Power)] INFO  [onent.AbstractOpenemsComponent] [_power] Modified Ess.Power
2024-05-30T13:19:13,630 [e.Cycle)] INFO  [onent.AbstractOpenemsComponent] [_cycle] Modified Core.Cycle
2024-05-30T13:19:13,632 [e.Cycle)] INFO  [onent.AbstractOpenemsComponent] [_cycle] Modified Core.Cycle
And the response is the same as OPs
    "jsonrpc": "2.0",
    "id": "c1d16b8d-ea7b-4e73-a2ac-227f97e66e41",
    "error": {
        "code": 1,
        "message": "Unable to get Response: A Singleton Component for PID [Ess.Power] is already existing!",
        "data": [
I’m trying to start a simulation with the configuration from our dev env with this JsonRPC:
  "method": "componentJsonApi",
  "params": {
    "componentId": "_simulator",
    "payload": {
      "method": "executeSimulation",
      "params": {
        "components": [
            "factoryPid": "Controller.Api.ModbusTcp.ReadOnly",
            "properties": [
                "name": "id",
                "value": "ctrlApiModbusTcp0"
                "name": "component.ids",
                "value": [
                  "_sum"
                "name": "maxConcurrentConnections",
                "value": 5
                "name": "port",
                "value": 502
                "name": "enabled",
                "value": false
            "factoryPid": "Controller.Api.Websocket",
            "properties": [
                "name": "id",
                "value": "ctrlApiRest0"
                "name": "apiTimeout",
                "value": 60
                "name": "port",
                "value": 8085
                "name": "enabled",
                "value": true
            "factoryPid": "Controller.CHP.SoC",
            "properties": [
                "name": "id",
                "value": "ctrlChpSoc0"
                "name": "alias",
                "value": "Control CHP (BHKW)"
                "name": "highThreshold",
                "value": 80
                "name": "inputChannelAddress",
                "value": "_sum/EssSoc"
                "name": "invert",
                "value": false
                "name": "lowThreshold",
                "value": 20
                "name": "mode",
                "value": "MANUAL_ON"
                "name": "outputChannelAddress",
                "value": "io0/InputOutput2"
                "name": "enabled",
                "value": true
            "factoryPid": "Controller.Debug.Log",
            "properties": [
                "name": "id",
                "value": "ctrlDebugLog0"
                "name": "enabled",
                "value": true
            "factoryPid": "Controller.Ess.LimitTotalDischarge",
            "properties": [
                "name": "id",
                "value": "ctrlLimitTotalDischarge0"
                "name": "ess.id",
                "value": "ess0"
                "name": "forceChargeSoc",
                "value": 40
                "name": "minSoc",
                "value": "15"
                "name": "enabled",
                "value": true
            "factoryPid": "Controller.Ess.Time-Of-Use-Tariff",
            "properties": [
                "name": "id",
                "value": "ctrlEssTimeOfUseTariff0"
                "name": "controlMode",
                "value": "CHARGE_CONSUMPTION"
                "name": "ess.id",
                "value": "ess0"
                "name": "ess.target",
                "value": "(&(enabled=true)(!(service.pid=Controller.Ess.Time-Of-Use-Tariff))(|(id=ess0)))"
                "name": "maxChargePowerFromGrid",
                "value": 20000
                "name": "mode",
                "value": "AUTOMATIC"
                "name": "riskLevel",
                "value": "MEDIUM"
                "name": "enabled",
                "value": true
            "factoryPid": "Scheduler.AllAlphabetically",
            "properties": [
                "name": "id",
                "value": "scheduler0"
                "name": "controllers.ids",
                "value": [
                  "ctrlLimitTotalDischarge0",
                  "ctrlBalancing0",
                "name": "alias",
                "value": ""
                "name": "enabled",
                "value": true
            "factoryPid": "Simulator.GridMeter.Reacting",
            "properties": [
                "name": "id",
                "value": "meter0"
                "name": "alias",
                "value": "Grid"
                "name": "enabled",
                "value": true
            "factoryPid": "Controller.IO.ChannelSingleThreshold",
            "properties": [
                "name": "id",
                "value": "ctrlChannelSingleThreshold0"
                "name": "alias",
                "value": "Control by Threshold"
                "name": "invert",
                "value": "true"
                "name": "minimumSwitchingTime",
                "value": 60
                "value": "io0/InputOutput0"
                "name": "switchedLoadPower",
                "value": 0
                "name": "mode",
                "name": "threshold",
                "value": 40
                "name": "enabled",
                "value": true
            "factoryPid": "Controller.IO.HeatingElement",
            "properties": [
                "name": "id",
                "value": "ctrlIoHeatingElement0"
                "name": "alias",
                "value": "Control Heating Element"
                "name": "defaultLevel",
                "value": "LEVEL_1"
                "name": "endTime",
                "value": "17:00"
                "name": "minTime",
                "value": 1
                "value": 60
                "name": "outputChannelPhaseL1",
                "value": "io0/InputOutput3"
                "name": "outputChannelPhaseL2",
                "value": "io0/InputOutput4"
                "name": "outputChannelPhaseL3",
                "value": "io0/InputOutput5"
                "name": "mode",
                "name": "powerPerPhase",
                "value": 2000
                "name": "workMode",
                "value": "TIME"
                "name": "enabled",
                "value": true
            "factoryPid": "Controller.Io.FixDigitalOutput",
            "properties": [
                "name": "id",
                "value": "ctrlIoFixDigitalOutput0"
                "name": "alias",
                "value": "Control Manually"
                "name": "isOn",
                "value": false
                "value": "io0/InputOutput1"
                "name": "enabled",
                "value": true
            "factoryPid": "Evcs.Predictor.PersistenceModel",
            "properties": [
                "name": "id",
                "value": "predictor0"
                "name": "BundleLocation",
                "value": "?"
                "name": "alias",
                "value": ""
                "name": "enabled",
                "value": true
                "name": "logVerbosity",
                "value": "REQUESTED_PREDICTIONS"
                "name": "channelAddresses",
                "value": [
                  "_sum/ProductionActivePower",
                  "_sum/UnmanagedConsumptionActivePower",
                  "_sum/ConsumptionActivePower"
            "factoryPid": "Simulator.NRCMeter.Acting",
            "properties": [
                "name": "id",
                "value": "meter3"
                "name": "alias",
                "value": "Xs Consumption"
                "name": "datasource.id",
                "value": "_simulator"
                "name": "enabled",
                "value": true
            "factoryPid": "TimeOfUseTariff.Pjm",
            "properties": [
                "name": "id",
                "value": "timeOfUseTariff0"
                "name": "filter",
                "value": "DOM (DA)"
                "name": "enabled",
                "value": true
            "factoryPid": "Timedata.InfluxDB",
            "properties": [
                "name": "id",
                "value": "influx0"
                "name": "apiKey",
                "value": "an apikey"
                "name": "bucket",
                "value": "timedata"
                "name": "isReadOnly",
                "value": false
                "name": "maxQueueSize",
                "value": 5000
                "name": "measurement",
                "value": "data"
                "name": "noOfCycles",
                "value": 1
                "name": "org",
                "value": "BSF"
                "name": "queryLanguage",
                "value": "INFLUX_QL"
                "name": "url",
                "value": "http://localhost:8086"
                "name": "enabled",
                "value": true
            "factoryPid": "Simulator.IO.DigitalInputOutput",
            "properties": [
                "name": "id",
                "value": "io0"
                "name": "alias",
                "value": "Simulated Relay-Board"
                "name": "numberOfOutputs",
                "value": 6
                "name": "enabled",
                "value": true
            "factoryPid": "Simulator.ProductionMeter.Acting",
            "properties": [
                "name": "id",
                "value": "meter2"
                "name": "alias",
                "value": "PV BRF Malmo"
                "name": "enabled",
                "value": true
            "factoryPid": "Controller.Symmetric.BalancingSchedule",
            "properties": [
                "name": "id",
                "value": "ctrlBalancing0"
                "name": "alias",
                "value": "Self-consumption optimization"
                "name": "ess.id",
                "value": "ess0"
                "value": "(&(enabled=true)(!(service.pid=Controller.Symmetric.BalancingSchedule))(|(id=ess0)))"
                "name": "meter.target",
                "value": "(&(enabled=true)(!(service.pid=Controller.Symmetric.BalancingSchedule))(|(id=meter0)))"
                "name": "meter.id",
                "value": "meter0"
                "name": "targetGridSetpoint",
                "value": 0
                "name": "enabled",
                "value": true
        "clock": {
          "start": "2023-01-01T00:00:00Z",
          "end": "2023-12-31T23:59:59Z",
          "timeleapPerCycle": 900000,
          "executeCycleTwice": false
        "collect": [
          "_sum/GridActivePower",
          "_sum/EssActivePower",
          "_sum/ConsumptionActivePower",
          "_sum/EssSoc"
        "profiles": {
          "meter3/ActivePower": [ "long list of numbers"
          "meter2/ActivePower": [
Even using the example JsonRpc results in the same error.
   "params":{
      "payload":{
         "method":"executeSimulation",
         "params":{
            "components":[
                  "factoryPid":"Scheduler.AllAlphabetically",
                  "properties":[
                        "name":"id",
                        "value":"scheduler0"
                  "factoryPid":"Simulator.GridMeter.Reacting",
                  "properties":[
                        "name":"id",
                        "value":"meter0"
                  "factoryPid":"Simulator.NRCMeter.Acting",
                  "properties":[
                        "name":"id",
                        "value":"meter1"
                        "name":"alias",
                        "value":"Consumption"
                        "name":"datasource.id",
                        "value":"_simulator"
                  "factoryPid":"Simulator.ProductionMeter.Acting",
                  "properties":[
                        "name":"id",
                        "value":"meter2"
                        "name":"alias",
                        "value":"South Roof"
                  "factoryPid":"Simulator.EssSymmetric.Reacting",
                  "properties":[
                        "name":"id",
                        "value":"ess0"
                        "name":"maxApparentPower",
                        "value":10000
                        "name":"capacity",
                        "value":10200
                        "name":"initialSoc",
                        "value":50
                  "factoryPid":"Controller.Symmetric.Balancing",
                  "properties":[
                        "name":"id",
                        "value":"ctrlBalancing0"
                        "name":"ess.id",
                        "value":"ess0"
                        "name":"meter.id",
                        "value":"meter0"
            "clock":{
               "start":"2000-01-01T00:00:00.00Z",
               "end":"2000-01-08T00:00:00.00Z",
               "timeleapPerCycle":900000,
               "executeCycleTwice":true
            "profiles":{
               "meter1/ActivePower": [436,404,373,344,316,290,267,248,236,227,220,216,211,207,203,199,196,193,192,191,191,191,193,195,198,201,206,211,219,232,254,290,342,405,474,543,607,666,719,767,810,849,886,924,962,999,1029,1049,1055,1047,1025,990,944,890,833,779,732,692,658,630,607,588,572,555,539,527,524,535,562,602,647,692,731,764,795,825,854,878,892,887,861,820,775,733,704,683,666,646,621,591,556,518,479,440,402,364,436,404,374,345,316,290,267,249,236,227,220,216,211,207,203,199,196,193,192,191,191,191,193,195,198,201,206,211,219,232,255,291,342,405,475,544,608,667,720,768,811,850,888,926,964,1000,1030,1050,1056,1048,1027,992,945,891,834,780,733,693,659,631,608,589,572,556,540,528,525,536,563,603,648,693,732,765,796,826,855,880,893,888,862,821,776,735,705,684,667,647,622,591,556,519,480,441,402,365,338,304,274,249,231,218,209,204,200,198,197,195,194,193,191,191,192,194,196,200,204,215,238,279,340,413,489,557,607,642,663,673,676,673,665,653,638,622,607,594,586,580,578,578,580,584,593,607,626,647,664,673,670,658,639,619,600,583,568,553,539,527,517,511,510,515,527,549,579,618,662,711,761,810,855,893,922,940,943,931,902,862,818,777,744,716,691,665,635,602,566,528,489,450,412,374,338,304,275,250,231,218,210,204,201,198,197,196,194,193,192,192,192,194,197,200,205,216,239,279,340,414,490,558,608,643,664,674,677,674,666,654,639,623,608,595,587,581,579,579,581,585,594,608,627,648,665,674,671,659,640,620,601,584,569,554,540,528,518,512,511,516,528,550,580,619,663,712,762,811,856,895,924,941,945,932,904,864,820,778,745,717,692,666,636,603,567,529,490,451,413,375,338,304,275,250,231,218,210,204,201,198,197,196,194,193,192,192,192,194,197,200,205,216,239,279,340,415,491,558,609,643,664,675,678,675,666,654,639,624,608,596,587,582,579,579,581,586,594,608,628,649,666,675,672,659,641,621,602,585,569,554,540,528,518,513,512,517,529,550,581,619,664,712,763,812,857,896,925,942,946,933,905,865,820,779,745,718,693,667,637,603,567,529,491,452,413,375,339,305,275,250,232,219,210,204,201,198,197,196,194,193,192,192,192,194,197,200,205,216,239,280,341,415,491,559,609,644,665,676,679,676,667,655,640,624,609,596,588,582,580,580,582,586,595,609,628,649,667,676,673,660,641,621,602,585,570,555,541,529,519,513,512,517,529,551,581,620,665,713,764,813,858,897,926,943,947,934,906,865,821,780,746,719,694,668,637,604,568,530,491,452,413,375,339,305,275,250,232,219,210,205,201,199,198,196,195,194,192,192,193,195,197,201,205,216,239,280,341,415,492,559,610,645,666,676,679,676,668,656,641,625,609,597,588,583,580,580,582,587,595,609,629,650,667,676,673,661,642,622,603,586,570,555,541,529,519,514,513,518,530,551,582,621,665,714,764,814,859,897,927,944,948,935,906,866,822,781,747,719,694,668,638,604,568,530,492,452,414,376],
               "meter2/ActivePower": [0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4,24,100,250,277,345,449,457,535,530,575,770,862,720,779,808,638,552,457,440,574,537,499,356,216,267,180,180,147,102,19,4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,6,23,105,162,223,271,309,370,431,463,514,481,463,516,467,406,375,361,401,387,372,345,334,337,312,275,229,184,141,96,20,4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,5,20,74,134,173,209,254,275,302,331,380,419,437,471,410,441,444,410,394,400,396,384,387,391,350,291,260,208,140,74,20,5,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3,24,130,215,278,378,443,529,534,568,797,726,618,766,703,802,809,755,783,682,633,672,590,629,515,523,403,318,251,171,31,3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,26,56,336,1979,945,2897,3580,2510,3097,3499,5616,6327,2631,898,3859,3909,4931,3683,5996,1777,3615,3415,1601,1254,4954,4145,3426,1163,101,457,27,5,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,6,21,65,25,48,84,108,125,123,99,84,119,214,202,183,104,151,450,881,1878,3424,5211,4329,3986,1796,1904,1618,1173,646,758,50,13,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,13,35,104,163,246,349,329,406,387,379,457,396,488,530,540,591,835,774,740,569,549,542,524,549,471,446,337,234,192,110,30,7,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
            "collect":[
               "_sum/EssSoc"
Response:
    "jsonrpc": "2.0",
    "id": "c5318708-bd4e-4d21-8864-353cced47c8d",
    "error": {
        "code": 1,
        "data": [
I’ve the same issue.
For now I fixed it by uncommenting the following lines and configure the existing Ess.Power controller manually (via the Apache Felix Console) to disable Enable PID Filter. This works without any side effects for me now. I also had to disable the cycle configuration, as I had an issue with that. I configured the cycle configuration manually and set the cycle time to 0.
Currently these are my changes to make the simulation working (they’re just a workaround for now, not an actual fix I’ll publish…):
diff --git a/io.openems.edge.simulator/src/io/openems/edge/simulator/app/SimulatorAppImpl.java b/io.openems.edge.simulator/src/io/openems/edge/simulator/app/SimulatorAppImpl.java
index ca6c12154..bc483581e 100644
--- a/io.openems.edge.simulator/src/io/openems/edge/simulator/app/SimulatorAppImpl.java
+++ b/io.openems.edge.simulator/src/io/openems/edge/simulator/app/SimulatorAppImpl.java
@@ -189,8 +189,8 @@ public class SimulatorAppImpl extends AbstractOpenemsComponent
                this.setCycleTime(AbstractWorker.ALWAYS_WAIT_FOR_TRIGGER_NEXT_RUN);
                // Create Ess.Power with disabled PID filter
-               this.componentManager.handleJsonrpcRequest(user,
-                               new CreateComponentConfigRequest("Ess.Power", Arrays.asList(new Property("enablePid", false))));
+//             this.componentManager.handleJsonrpcRequest(user,
+//                             new CreateComponentConfigRequest("Ess.Power", Arrays.asList(new Property("enablePid", false))));
                // Create Components
                Set<String> simulatorComponentIds = new HashSet<>();
@@ -402,7 +402,7 @@ public class SimulatorAppImpl extends AbstractOpenemsComponent
                        var config = this.cm.getConfiguration("Core.Cycle", null);
                        Dictionary<String, Object> properties = new Hashtable<>();
                        properties.put("cycleTime", cycleTime);
-                       config.update(properties);
+//                     config.update(properties);
                } catch (IOException e) {
                        this.logError(this.log, "Unable to configure Core Cycle-Time. " + e.getClass() + ": " + e.getMessage());
I’m currently working on fixing this, but had some follow up issues I’m currently working on as well (caution - still speculative root causing: cycle configuration is not updated properly resulting cycle thread hangs in await state (is a bit of a flaky bug, but happens more often than not); component creation/retrieval via osgi not working for everything in the simulation setup, e.g. time of use controller). I hope I’ll be able to publish a pull request for this next week.
I’ve created a merge request to fix the Ess.Power issue. Took a bit longer than announced, sorry for that.
When I find the time, I’ll continue to look into the other issues I’ve mentioned (cycle time issue for the simulation)
