I’m trying to run OpenEMS and use OpenEMS getting started, but when I want to
do the first step I want to create the scheduler All Alphabetically. An Ajax error occurs. How can I fix it?
Best regards
Do you start the jar file inside an IDE? I think it is a problem with the runproperties. There you need to specify where OpenEms stores the configuration. Default is C:/openems/config and C:/openems/data. I assume you are on a linux distribution. Please update EdgeApp file to use runproperties with a path that is valid for your os.
You can also overwritte these parameter when starting the .jar file
felix.cm.diropenems.data.dirI hope that helps. Greetings!
Use the precompiled Version for starting purposes. Is easier to understand at first glance.
I run this JAR file in a terminal using this command as you described: java -Dfelix.cm.dir=/etc/openems.d -Dopenems.data.dir=/home/root/openems/data/ - jar openems-edge.jar
Unfortunately this gives me this error
did you maybe forget sudo?
Just to elaborate a bit on this:
The command:
/etc/openems.d. This is where Apache Felix Configuration Admin stores its files/home/root/openems/data/. This is where OpenEMS stores files like RRD4j timeseries databasesTo be able to write to /etc/openems.d, root privileges are required. This is why sudo has to be used here, i.e. sudo java -Dfelix.cm.dir=/etc/openems.d -Dopenems.data.dir=/home/root/openems/data/ - jar openems-edge.jar
Similar approach is used here in the docs:
https://openems.github.io/openems.io/openems/latest/edge/deploy.html
Sstefan
