Hello OpenEMS community,
I have recently started working with OpenEMS and discovered an important feature in Odoo-OpenEMS that notifies the edge owner when the system is offline or encounters a fault. However, while testing this feature, I ran into some issues and would appreciate any guidance on resolving them.
I am running Odoo (Odoo 16 + OpenEMS add-on), PostgreSQL, OpenEMS backend, OpenEMS UI, and InfluxDB using Docker Compose.
Issues:
- UI Error:
When accessing the UI, I encounter the following error:
Cannot read properties of undefined (reading 'userLogin')
This occurs in this file on line 23.
I temporarily resolved it by commenting out the affected code, but I am looking for a proper solution.
2. Odoo Error when configuring Offline Notification Delays:
When I attempt to configure the “Offline Notification” delay in Odoo, I receive the following error:
Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/odoo/models.py", line 5183, in ensure_one
_id, = self._ids
ValueError: too many values to unpack (expected 1)
During handling of the above exception, another exception occurred:
File "/usr/lib/python3/dist-packages/odoo/models.py", line 5186, in ensure_one
raise ValueError("Expected singleton: %s" % self)
ValueError: Expected singleton: openems.device_user_role(49, 53)
Additional Context:
- Alerting in the backend is enabled.
- The SMTP server (Outgoing Mail Server) is activated in Odoo and successfully tested.
I would greatly appreciate any guidance on resolving these issues.
Best regards,
