Backend to UI authentication
I have edge, backend, backend.edge and UI running.
I am in a situation where I can connect Edge directly to UI[1], but I no longer have the option to connect Backend to UI[2] unless I use Metadatafile or MetadataDummy. The implementation of authentication using a password in the aforementioned Metadata configurations is missing.
Controller Api Websocket port 8085
Ui.WebsocketUi.Websocket port 8085
Am I missing something? or is the only option to use Oauth?
