Hello!
I got this error when I try to run the BackEnd app in Eclipse (“Run OSGi”).
! Failed to start bundle org.apache.servicemix.bundles.xmlrpc-client-3.1.3.1, exception Could not resolve module: org.apache.servicemix.bundles.xmlrpc-client [38]
Unresolved requirement: Import-Package: javax.xml.bind
org.osgi.framework.BundleException: Could not resolve module: org.apache.servicemix.bundles.xmlrpc-client [38]
at org.eclipse.osgi.container.Module.start(Module.java:463)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:439)
at aQute.launcher.Launcher.start(Launcher.java:674)
at aQute.launcher.Launcher.startBundles(Launcher.java:654)
at aQute.launcher.Launcher.activate(Launcher.java:560)
at aQute.launcher.Launcher.launch(Launcher.java:400)
at aQute.launcher.Launcher.run(Launcher.java:181)
at aQute.launcher.Launcher.main(Launcher.java:157)
at aQute.launcher.pre.EmbeddedLauncher.executeWithRunPath(EmbeddedLauncher.java:170)
at aQute.launcher.pre.EmbeddedLauncher.findAndExecute(EmbeddedLauncher.java:135)
at aQute.launcher.pre.EmbeddedLauncher.main(EmbeddedLauncher.java:52)
org.ops4j.pax.logging.pax-logging-api [org.ops4j.pax.logging.internal.Activator] INFO : Enabling Java Util Logging API support.
Has someone met this issue? What can be the problem? Thank you.
this might be an issue with the Java version you are using to run OpenEMS. OpenEMS is still using version Java version 8, and it seems that javax.xml.bind was dropped in more recent versions. I found this on Stackoverflow:
Could it be, that you are running it with Java 11?
For a OpenEMS Edge-Backend-UI setup that “just works”, I can also recommend our gitpod setup:
