Hi folks, hope you are doing well
I am new to OpenEMS. I already have a backend (Controller API Backend) that receives data from OpenEMS. I want to configure a battery so that the backend receives ESS state of charge (SoC), max/min voltage, and max/min temperature in JSON format.
From what I understand, to set up battery voltage, temperature, charging/discharging, etc., we should configure the Simulator Battery . I have also configured the Simulator Modbus Bridge because it is required for the Battery-Inverter Sinexcel . This setup is necessary because the ESS Generic Managed Symmetric configuration needs both Battery-Inverter and Battery IDs to create an ESS instance. I use the created ESS (in my case, with ID 'ess3 ') in the Controller ESS Fix Active Power . As I understand it required controller to send battery data to our backend. But with this configuration OpenEms still do not send battery data, here is log rom openEms:
2024-11-14T15:44:14,000 [Worker-0] INFO [ackend.SendChannelValuesWorker] [ctrlBackend0] Sending [33 values]: {meter1/ActivePowerL2=382, meter1/ActivePowerL3=382, meter1/ActivePowerL1=382, ess0/ActivePowerL3=402, meter0/ActivePower=-60, ess0/ActivePowerL1=402, meter1/ActivePower=1146, ess0/ActivePowerL2=402, _sum/ProductionAcActivePowerL3=382, _sum/ProductionAcActivePowerL1=382, _sum/EssActivePowerL1=394, _sum/ProductionAcActivePowerL2=382, _sum/EssActivePowerL2=394, _sum/EssActivePowerL3=394, _sum/GridActivePower=-60, meter0/ActivePowerL3=-20, meter0/ActivePowerL2=-20, meter0/ActivePowerL1=-20, _sum/UnmanagedConsumptionActivePower=2267, _sum/ProductionAcActivePower=1146, ess1/ActivePower=1181, ess0/ActivePower=1206, ess1/DebugSetActivePower=1181, _sum/EssDischargePower=1181, _sum/ConsumptionActivePower=2267, _sum/ProductionActivePower=1146, _sum/ConsumptionActivePowerL3=756, _sum/ConsumptionActivePowerL1=756, _sum/ConsumptionActivePowerL2=756, _sum/EssActivePower=1181, _sum/GridActivePowerL3=-20, _sum/GridActivePowerL2=-20, _sum/GridActivePowerL1=-20}
2024-11-14T15:44:14,001 [_cycle ] INFO [ebuglog.ControllerDebugLogImpl] [ctrlDebugLog0] _sum[State:Fault Ess SoC:47 %|L:1181 W Grid:-60 W Production:1146 W Consumption:2267 W] batteryInverter0[GoStopped|Grid:Undefined] ctrlBackend0[State:WARNING: UnableToSend] ess1[SoC:47 %|L:1181 W|Allowed:-10000;10000 W] ess3[Error|SoC:50 %|L:UNDEFINED|Allowed:0;0|State:FAULT: Start battery inverter timeout passed!] meter0[-60 W] meter1[1146 W]
What am I missing? Could someone please suggest any improvements? Additionally, I would like to receive ESS state of charge (SoC), max/min voltage, max/min temperature, and reactive power.
