Hello Everyone I am new to this OpenEMS structure and I am trying to figure out something. I have a function in the OpenEMS Edge that calls an API, fetches a result, and sends it to OpenEMS UI below is the code for Edge and UI both. what I am trying to figure out is how UI is contacting the Edge and if I need to set up another API response to display in UI what should I do ?
EDGE CODE
public class ExecuteTradeGroupResponse extends JsonrpcResponseSuccess {
private static final String API_URL = "http://localhost:7005/api/community/community2gui/pools";
public ExecuteTradeGroupResponse(UUID id) {
super(id);
public ExecuteTradeGroupResponse(UUID id, JsonElement params) {
super(id);
String tradeGroups = params.toString();
BufferedWriter bw = null;
System.err.println(" Called ExecuteTradeGroupRequest: " + tradeGroups);
if (tradeGroups.toLowerCase().contains("groups")) {
String jsonFilename = ControllerBestTradeGroups.cacheJSON;
// System.out.println("STORING to "+jsonFilename);
File file = new File(jsonFilename);
try {
if (!file.exists())
file.createNewFile();
FileWriter fw = new FileWriter(jsonFilename);
bw = new BufferedWriter(fw);
bw.write(tradeGroups);
bw.close();
} catch (Exception e) {
e.printStackTrace();
System.err.println("File not written Successfully");
@Override
public JsonObject getResult() {
final OkHttpClient client = new OkHttpClient();
Request request = new Request.Builder().url(API_URL).build();
try (Response response = client.newCall(request).execute()) {
if (!response.isSuccessful()) {
throw new IOException("Unexpected code " + response);
String responseBodyString = response.body().string();
Gson gson = new GsonBuilder().setPrettyPrinting().create();
List<Object> responseList = gson.fromJson(responseBodyString, ArrayList.class);
JsonObject tradeGroupsWrapper = new JsonObject();
tradeGroupsWrapper.add("tradeGroups", gson.toJsonTree(responseList));
tradeGroupsWrapper.addProperty("InviteCode","test");
return tradeGroupsWrapper;
} catch (IOException e) {
System.err.println("[ERROR] " + e.getMessage());
System.out.print("No Response");
System.err.println("[ERROR] No Response");
return null;
UI CODE
this.service.getCurrentEdge().then((edge) => {
let request = new ComponentJsonApiRequest({
componentId: "tradegroups0",
payload: new GetTradeGroupsRequest({
action: "read",
properties: "{}",
param: "test",
edge
.sendRequest(this.service.websocket, request)
.then((response) => {
console.log(
"Trade Groups Data Response Is " + JSON.stringify(response.result)
this.tradeGroupsObject = JSON.parse(
).tradeGroups;
this.ngOnInitPart2();
.catch((reason) => {
console.warn(reason);
