I want to integrate the openEMS modbus tcp with Kepware modbus TCP.
Is it possible or not?
As fas as i understand Kepware you can integrate there everything?! so sure should it be possible if you know how to configurate the kepware software
Can you please share the link/screenshot of configuration UI of OpenEMS modbus TCP?
just activate the modbus depending to your needs with only read or write rights.
