Clarification on starting Edge using Docker
I am having issues running the Edge docker container. With the image from https://hub.docker.com/r/openems/edge, I ran
docker run --name openems_edge -p 8080:8080 -d openems/edge
The container logs show
11:05:12.039 [_cycle] INFO io.openems.edge.controller.debuglog.ControllerDebugLogImpl - [ctrlDebugLog0] _appManager[AppValidateWorker=App.Core.Meta[App.Core.Meta: JSON [null] is not an Enum], waitingForModified=false|State:INFO: Defekte App erkannt] _componentManager[State:FAULT: Applying the default configuration failed.] _sum[State:Fault]
I assume this is likely a missing configuration file issue. Where can I find a template for a configuration file and where do I need to place it ?
Best regards
If you haven’t got it working yet, the getting started tutorial points to the How to use OpenEMS docker images which should give you a hint about the config.
HTH
