Hello, I recently created four edges and successfully implemented them into the backend. Now, I can access all these edges from the backend UI and view their respective charts. However, my goal is to combine the production data from all the edges into a single chart. Is this possible? Looking for guidance on how to achieve this. Thank you!
Hi.
Right now this is not possible with OpenEMS Backend and OpenEMS UI - and it will certainly require some refactoring.
But of couse, you can always combine the InfluxDB in Grafana dashboards. It should be relatively easy to create such a single-chart there.
Does that help for your use-case?
Yes thank you so much
