Contribute to OpenEMS, running as FEMS
I would like to analyze and correct two bugs within the Hardy Barth charging app which show up as when I try to charge my car via my FEMS system.
I already have an OpenEMS system running on my local dev machine, but I cannot use it with my Hardy Barth cpμ2 charging station, as it is connected to the FEMS system. I also believe that the bugs are related with the integration to my solar power installation and the excess charge mode. So even if I could somehow switch my charger to the OpenEMS installation, this would likely be a dead end.
How can I analyze the problem in the FEMS system? Ideally, I would like to also deploy logging extensions and potential fixes to the system.
