I am experimenting with configuring OpenEMS Edge entirely via the REST API.
I notice that the API contains the concepts of "components" and "factories" where components are the actually existing components - identified by parameters such as “ess0” etc that are defined when they are created.
I noted the function updateComponentConfig in the docs for the REST API which allows us to update the config of an already running components - e.g changing parameters or activating/deactivating them.
My question is whether it is possible to instantiate components for the first time from factories using JSONRPC calls? E.g if I wanted to create an instance of a component such as Controller.Ess.GridOptimizedCharge because I want my edge system to start using this controller.
