Hello everyone!
I am trying to develop a new widget using the Step by step guide (Implementing a UI-Widget :: Open Energy Management System). However I am having some doubts.
As the guide says I copied an already existing module ([FixActivePower]), however I cannot understand where do I define which element will be feeding this New module of information. Example: I created a evcs device in edge (however it only creates random values, which i can see in the terminal in eclipse). Maybe I am just getting confused with the names.
Finally I would like to then plot these values in a chart, to which the guide mentions to use a historic view, however the link to the working example doesnt work. https://openems.github.io/openems.io/openems/latest/ui/implementing-a-widget/components/src/app/edge/history/common/autarchy/chart/chart.ts
Is there another guide with more details?
Thank you very much in advance. ![]()
