Following the Simulated Meter Implementation Guide Results in Errors
I am a beginner to OpenEMS and I tried to follow the OpenEMS guide to implementing a device.
I did this on windows 10, and all the other beginner tutorials have worked fine on this computer.
As far as I can tell I followed the guide exactly but I ran into errors and ultimately could not finish the implementation of the device. I was wondering if anyone here might be able to provide guidance as it seems like the issues I am running into are not discussed on the forum.
The first indicator that something was wrong was an error rather than a warning at step 1.2.1 Define Bundle dependencies
However I continued to follow the rest of the instructions hoping that this error would go away (it didn’t).
After completing the steps up to 1.7 Enable The Component, I had to stop since the “Update” button was greyed out.
Here are all errors and issues I was having once I reached this point:
Error: builder cannot be resolved or is not a field
Error: Exception OpenemsException is not compatible with throws clause in AbstractOpenemsModbus…
The method type() of type MyConfigBuilder must override or implement a supertype method
The type MyConfig must implement the inherited abstract method Config.type()
Resolution failed, Capabilities satisfying the following requirements could not be found
Any help or insight at all with these issues would be greatly appreciated, thank you for reading!
Edited for clarity and spelling.
Hi, I think the reason is that the code templates haven’t been adapted to recent changes in the source code.
I know that the method defineModbusProtocol() does not throw an exception anymore, so you can simply remove the throws OpenemsException there.
I don’t know About the errors in the MyConfig, you can either hover over the error and see some “quick fixes” that can give you guidance, or maybe a better idea would be to have a look at the MyConfig of another modbus meter.
Best regards,
@tsicking Deleting the throws OpenemsException worked to remove the error, thank you so much for your help!
Unfortunately resolution is still not working properly, I get the message:
Resolution failed. Capabilities satisfying the following requirements could not be found:
    [<<INITIAL>>]
      ⇒ osgi.identity: (osgi.identity=io.openems.edge.katek.edcom)
          ⇒ [io.openems.edge.katek.edcom version=1.0.0.202406271936]
              ⇒ osgi.ee: (&(osgi.ee=JavaSE)(version=17))
    [slf4j.api__0 version=1.8.0.beta4 type=bnd.synthetic]
      ⇒ osgi.ee: (&(osgi.ee=JavaSE)(&(version>=0.0.0)(!(version>=9.0.0))))
    [org.slf4j.api__8 version=2.0.6 type=bnd.synthetic]
      ⇒ osgi.ee: (&(osgi.ee=JavaSE)(&(version>=1.8.0)(!(version>=9.0.0))))
    [slf4j.api__8 version=2.0.9 type=bnd.synthetic]
    [org.ops4j.pax.logging.pax-logging-api__8 version=2.2.1 type=bnd.synthetic]
    [Java-WebSocket__7 version=1.5.4 type=bnd.synthetic]
      ⇒ osgi.ee: (&(osgi.ee=JavaSE)(&(version>=1.7.0)(!(version>=9.0.0))))
    [com.google.gson__7 version=2.10.1 type=bnd.synthetic]
    [com.google.gson__7 version=2.11.0 type=bnd.synthetic]
    [io.openems.wrapper.jenetics version=7.2.0]
      ⇒ osgi.wiring.package: (osgi.wiring.package=java.util.random)
    [osgi.cmpn version=7.0.0.201802012110]
      ⇒ osgi.unresolvable: (&(must.not.resolve=*)(!(must.not.resolve=*)))
    [io.openems.common version=1.0.0.202406271936]
    [org.slf4j.api version=2.0.6]
      ⇒ osgi.extender: (&(osgi.extender=osgi.serviceloader.processor)(version>=1.0.0)(!(version>=2.0.0)))
    [slf4j.api version=2.0.9]
    [ch.qos.logback.classic version=1.2.3]
     ⇒ osgi.wiring.package: (&(osgi.wiring.package=ch.qos.logback.core.util)(version>=1.2.0)(!(version>=2.0.0)))
For the other errors I encountered, I was about to follow your advice when, for some reason, eclipse stopped loading the workspace I was using properly, so I ended up redoing the whole setup process on a different openems workspace that I had. I’m thinking that there were three potential causes to my problems: perhaps there was an issue with my workspace that I wasn’t aware of, maybe the other issues were somehow connected to the throws OpenemsException part of the code, and also there was a small difference in how I followed the instructions this time: When adding the type configuration to the MyModbusDeviceTest.java file I noticed that there were some differences between the code shown there what I had so instead of a direct copy-paste I simply added in the additional lines.
I noticed that in the imports I had an extra line not reflected in the code on the website:
import io.openems.edge.common.test.DummyConfigurationAdmin;
I had to add two lines:
import io.openems.edge.meter.api.MeterType; with the other import statements
and the obvious:
.setType(MeterType.GRID) // in the body of the code
To provide additional information, this is the full code in io.openems.edge.application/EdgeApp.bndrun:
-runfw: org.apache.felix.framework;version='[7.0.5,7.0.5]'
-runee: JavaSE-16
-runprovidedcapabilities: ${native_capability}
-resolve.effective: active
-runproperties:\
                org.osgi.service.http.port=8080,\
                felix.cm.dir=c:/openems/config,\
                openems.data.dir=c:/openems/data,\
                org.apache.felix.eventadmin.Timeout=0,\
                org.ops4j.pax.logging.DefaultServiceLog.level=INFO
-runsystempackages:\
                sun.misc,\
                com.sun.net.httpserver
-runblacklist:\
                bnd.identity;id='org.osgi.service.cm',\
-runbundles+: \
                org.apache.felix.scr;startlevel=10,\
                org.apache.felix.configadmin;startlevel=11,\
                org.apache.felix.eventadmin;startlevel=12,\
                org.apache.felix.fileinstall;startlevel=13,\
                org.ops4j.pax.logging.pax-logging-api;startlevel=14,\
                org.ops4j.pax.logging.pax-logging-log4j2;startlevel=15,\
                io.openems.edge.application;startlevel=16,\
-runrequires: \
                bnd.identity;id='org.ops4j.pax.logging.pax-logging-api',\
                bnd.identity;id='org.ops4j.pax.logging.pax-logging-log4j2',\
                bnd.identity;id='org.apache.felix.http.jetty',\
                bnd.identity;id='org.apache.felix.webconsole',\
                bnd.identity;id='org.apache.felix.webconsole.plugins.ds',\
                bnd.identity;id='org.apache.felix.inventory',\
                bnd.identity;id='org.apache.felix.eventadmin',\
                bnd.identity;id='org.apache.felix.fileinstall',\
                bnd.identity;id='org.apache.felix.metatype',\
                bnd.identity;id='io.openems.edge.application',\
                bnd.identity;id='io.openems.edge.battery.bmw',\
                bnd.identity;id='io.openems.edge.battery.bydcommercial',\
                bnd.identity;id='io.openems.edge.battery.fenecon.commercial',\
                bnd.identity;id='io.openems.edge.battery.fenecon.home',\
                bnd.identity;id='io.openems.edge.battery.soltaro',\
                bnd.identity;id='io.openems.edge.batteryinverter.kaco.blueplanetgridsave',\
                bnd.identity;id='io.openems.edge.batteryinverter.refu88k',\
                bnd.identity;id='io.openems.edge.batteryinverter.sinexcel',\
                bnd.identity;id='io.openems.edge.batteryinverter.sunspec',\
                bnd.identity;id='io.openems.edge.bosch.bpts5hybrid',\
                bnd.identity;id='io.openems.edge.bridge.http',\
                bnd.identity;id='io.openems.edge.bridge.mbus',\
                bnd.identity;id='io.openems.edge.bridge.modbus',\
                bnd.identity;id='io.openems.edge.bridge.onewire',\
                bnd.identity;id='io.openems.edge.common',\
                bnd.identity;id='io.openems.edge.controller.api.backend',\
                bnd.identity;id='io.openems.edge.controller.api.common',\
                bnd.identity;id='io.openems.edge.controller.api.modbus',\
                bnd.identity;id='io.openems.edge.controller.api.mqtt',\
                bnd.identity;id='io.openems.edge.controller.api.rest',\
                bnd.identity;id='io.openems.edge.controller.api.websocket',\
                bnd.identity;id='io.openems.edge.controller.asymmetric.balancingcosphi',\
                bnd.identity;id='io.openems.edge.controller.asymmetric.fixreactivepower',\
                bnd.identity;id='io.openems.edge.controller.asymmetric.peakshaving',\
                bnd.identity;id='io.openems.edge.controller.asymmetric.phaserectification',\
                bnd.identity;id='io.openems.edge.controller.channelthreshold',\
                bnd.identity;id='io.openems.edge.controller.chp.soc',\
                bnd.identity;id='io.openems.edge.controller.debug.detailedlog',\
                bnd.identity;id='io.openems.edge.controller.debug.log',\
                bnd.identity;id='io.openems.edge.controller.ess.acisland',\
                bnd.identity;id='io.openems.edge.controller.ess.activepowervoltagecharacteristic',\
                bnd.identity;id='io.openems.edge.controller.ess.balancing',\
                bnd.identity;id='io.openems.edge.controller.ess.cycle',\
                bnd.identity;id='io.openems.edge.controller.ess.delaycharge',\
                bnd.identity;id='io.openems.edge.controller.ess.delayedselltogrid',\
                bnd.identity;id='io.openems.edge.controller.ess.emergencycapacityreserve',\
                bnd.identity;id='io.openems.edge.controller.ess.fixactivepower',\
                bnd.identity;id='io.openems.edge.controller.ess.fixstateofcharge',\
                bnd.identity;id='io.openems.edge.controller.ess.gridoptimizedcharge',\
                bnd.identity;id='io.openems.edge.controller.ess.hybrid.surplusfeedtogrid',\
                bnd.identity;id='io.openems.edge.controller.ess.limittotaldischarge',\
                bnd.identity;id='io.openems.edge.controller.ess.linearpowerband',\
                bnd.identity;id='io.openems.edge.controller.ess.mindischargeperiod',\
                bnd.identity;id='io.openems.edge.controller.ess.reactivepowervoltagecharacteristic',\
                bnd.identity;id='io.openems.edge.controller.ess.selltogridlimit',\
                bnd.identity;id='io.openems.edge.controller.ess.standby',\
                bnd.identity;id='io.openems.edge.controller.ess.timeofusetariff',\
                bnd.identity;id='io.openems.edge.controller.evcs',\
                bnd.identity;id='io.openems.edge.controller.evcs.fixactivepower',\
                bnd.identity;id='io.openems.edge.controller.generic.jsonlogic',\
                bnd.identity;id='io.openems.edge.controller.highloadtimeslot',\
                bnd.identity;id='io.openems.edge.controller.io.alarm',\
                bnd.identity;id='io.openems.edge.controller.io.analog',\
                bnd.identity;id='io.openems.edge.controller.io.channelsinglethreshold',\
                bnd.identity;id='io.openems.edge.controller.io.fixdigitaloutput',\
                bnd.identity;id='io.openems.edge.controller.io.heatingelement',\
                bnd.identity;id='io.openems.edge.controller.io.heatpump.sgready',\
                bnd.identity;id='io.openems.edge.controller.pvinverter.fixpowerlimit',\
                bnd.identity;id='io.openems.edge.controller.pvinverter.selltogridlimit',\
                bnd.identity;id='io.openems.edge.controller.symmetric.balancingschedule',\
                bnd.identity;id='io.openems.edge.controller.symmetric.fixreactivepower',\
                bnd.identity;id='io.openems.edge.controller.symmetric.limitactivepower',\
                bnd.identity;id='io.openems.edge.controller.symmetric.peakshaving',\
                bnd.identity;id='io.openems.edge.controller.symmetric.randompower',\
                bnd.identity;id='io.openems.edge.controller.symmetric.timeslotpeakshaving',\
                bnd.identity;id='io.openems.edge.core',\
                bnd.identity;id='io.openems.edge.edge2edge',\
                bnd.identity;id='io.openems.edge.energy',\
                bnd.identity;id='io.openems.edge.ess.adstec.storaxe',\
                bnd.identity;id='io.openems.edge.ess.byd.container',\
                bnd.identity;id='io.openems.edge.ess.cluster',\
                bnd.identity;id='io.openems.edge.ess.core',\
                bnd.identity;id='io.openems.edge.ess.fenecon.commercial40',\
                bnd.identity;id='io.openems.edge.ess.generic',\
                bnd.identity;id='io.openems.edge.ess.mr.gridcon',\
                bnd.identity;id='io.openems.edge.ess.samsung',\
                bnd.identity;id='io.openems.edge.ess.sma',\
                bnd.identity;id='io.openems.edge.evcs.alpitronic.hypercharger',\
                bnd.identity;id='io.openems.edge.evcs.cluster',\
                bnd.identity;id='io.openems.edge.evcs.core',\
                bnd.identity;id='io.openems.edge.evcs.dezony',\
                bnd.identity;id='io.openems.edge.evcs.goe.chargerhome',\
                bnd.identity;id='io.openems.edge.evcs.hardybarth',\
                bnd.identity;id='io.openems.edge.evcs.keba.kecontact',\
                bnd.identity;id='io.openems.edge.evcs.ocpp.abl',\
                bnd.identity;id='io.openems.edge.evcs.ocpp.common',\
                bnd.identity;id='io.openems.edge.evcs.ocpp.ies.keywatt.singleccs',\
                bnd.identity;id='io.openems.edge.evcs.ocpp.server',\
                bnd.identity;id='io.openems.edge.evcs.spelsberg',\
                bnd.identity;id='io.openems.edge.evcs.webasto.next',\
                bnd.identity;id='io.openems.edge.evcs.webasto.unite',\
                bnd.identity;id='io.openems.edge.fenecon.dess',\
                bnd.identity;id='io.openems.edge.fenecon.mini',\
                bnd.identity;id='io.openems.edge.fenecon.pro',\
                bnd.identity;id='io.openems.edge.goodwe',\
                bnd.identity;id='io.openems.edge.io.filipowski',\
                bnd.identity;id='io.openems.edge.io.gpio',\
                bnd.identity;id='io.openems.edge.io.kmtronic',\
                bnd.identity;id='io.openems.edge.io.offgridswitch',\
                bnd.identity;id='io.openems.edge.io.revpi',\
                bnd.identity;id='io.openems.edge.io.shelly',\
                bnd.identity;id='io.openems.edge.io.wago',\
                bnd.identity;id='io.openems.edge.io.weidmueller',\
                bnd.identity;id='io.openems.edge.kaco.blueplanet.hybrid10',\
                bnd.identity;id='io.openems.edge.katek.edcom',\
                bnd.identity;id='io.openems.edge.kostal.piko',\
                bnd.identity;id='io.openems.edge.meter.abb',\
                bnd.identity;id='io.openems.edge.meter.artemes.am2',\
                bnd.identity;id='io.openems.edge.meter.bcontrol.em300',\
                bnd.identity;id='io.openems.edge.meter.bgetech',\
                bnd.identity;id='io.openems.edge.meter.camillebauer.aplus',\
                bnd.identity;id='io.openems.edge.meter.carlo.gavazzi.em300',\
                bnd.identity;id='io.openems.edge.meter.discovergy',\
                bnd.identity;id='io.openems.edge.meter.eastron',\
                bnd.identity;id='io.openems.edge.meter.janitza',\
                bnd.identity;id='io.openems.edge.meter.kdk',\
                bnd.identity;id='io.openems.edge.meter.phoenixcontact',\
                bnd.identity;id='io.openems.edge.meter.plexlog',\
                bnd.identity;id='io.openems.edge.meter.pqplus',\
                bnd.identity;id='io.openems.edge.meter.schneider.acti9.smartlink',\
                bnd.identity;id='io.openems.edge.meter.siemens',\
                bnd.identity;id='io.openems.edge.meter.sma.shm20',\
                bnd.identity;id='io.openems.edge.meter.socomec',\
                bnd.identity;id='io.openems.edge.meter.sunspec',\
                bnd.identity;id='io.openems.edge.meter.virtual',\
                bnd.identity;id='io.openems.edge.meter.weidmueller',\
                bnd.identity;id='io.openems.edge.meter.ziehl',\
                bnd.identity;id='io.openems.edge.onewire.thermometer',\
                bnd.identity;id='io.openems.edge.predictor.persistencemodel',\
                bnd.identity;id='io.openems.edge.predictor.similardaymodel',\
                bnd.identity;id='io.openems.edge.pvinverter.cluster',\
                bnd.identity;id='io.openems.edge.pvinverter.fronius',\
                bnd.identity;id='io.openems.edge.pvinverter.kaco.blueplanet',\
                bnd.identity;id='io.openems.edge.pvinverter.kostal',\
                bnd.identity;id='io.openems.edge.pvinverter.sma',\
                bnd.identity;id='io.openems.edge.pvinverter.solarlog',\
                bnd.identity;id='io.openems.edge.pvinverter.sunspec',\
                bnd.identity;id='io.openems.edge.scheduler.allalphabetically',\
                bnd.identity;id='io.openems.edge.scheduler.daily',\
                bnd.identity;id='io.openems.edge.scheduler.fixedorder',\
                bnd.identity;id='io.openems.edge.simulator',\
                bnd.identity;id='io.openems.edge.solaredge',\
                bnd.identity;id='io.openems.edge.tesla.powerwall2',\
                bnd.identity;id='io.openems.edge.timedata.influxdb',\
                bnd.identity;id='io.openems.edge.timedata.rrd4j',\
                bnd.identity;id='io.openems.edge.timeofusetariff.awattar',\
                bnd.identity;id='io.openems.edge.timeofusetariff.corrently',\
                bnd.identity;id='io.openems.edge.timeofusetariff.entsoe',\
                bnd.identity;id='io.openems.edge.timeofusetariff.groupe',\
                bnd.identity;id='io.openems.edge.timeofusetariff.hassfurt',\
                bnd.identity;id='io.openems.edge.timeofusetariff.rabotcharge',\
                bnd.identity;id='io.openems.edge.timeofusetariff.tibber',\
                bnd.identity;id='io.openems.meter.simulated';version=latest
-runbundles: \
                Java-WebSocket;version='[1.5.4,1.5.5)',\
                bcpkix;version='[1.70.0,1.70.1)',\
                bcprov;version='[1.70.0,1.70.1)',\
                bcutil;version='[1.70.0,1.70.1)',\
                com.fazecast.jSerialComm;version='[2.10.4,2.10.5)',\
                com.ghgande.j2mod;version='[3.2.1,3.2.2)',\
                com.google.gson;version='[2.11.0,2.11.1)',\
                com.google.guava;version='[33.2.1,33.2.2)',\
                com.google.guava.failureaccess;version='[1.0.2,1.0.3)',\
                com.squareup.okio;version='[3.9.0,3.9.1)',\
                com.sun.jna;version='[5.14.0,5.14.1)',\
                io.openems.common;version=snapshot,\
                io.openems.edge.application;version=snapshot,\
                io.openems.edge.battery.api;version=snapshot,\
                io.openems.edge.battery.bmw;version=snapshot,\
                io.openems.edge.battery.bydcommercial;version=snapshot,\
                io.openems.edge.battery.fenecon.commercial;version=snapshot,\
                io.openems.edge.battery.fenecon.home;version=snapshot,\
                io.openems.edge.battery.soltaro;version=snapshot,\
                io.openems.edge.batteryinverter.api;version=snapshot,\
                io.openems.edge.batteryinverter.kaco.blueplanetgridsave;version=snapshot,\
                io.openems.edge.batteryinverter.refu88k;version=snapshot,\
                io.openems.edge.batteryinverter.sinexcel;version=snapshot,\
                io.openems.edge.batteryinverter.sunspec;version=snapshot,\
                io.openems.edge.bosch.bpts5hybrid;version=snapshot,\
                io.openems.edge.bridge.http;version=snapshot,\
                io.openems.edge.bridge.mbus;version=snapshot,\
                io.openems.edge.bridge.modbus;version=snapshot,\
                io.openems.edge.bridge.onewire;version=snapshot,\
                io.openems.edge.common;version=snapshot,\
                io.openems.edge.controller.api;version=snapshot,\
                io.openems.edge.controller.api.backend;version=snapshot,\
                io.openems.edge.controller.api.common;version=snapshot,\
                io.openems.edge.controller.api.modbus;version=snapshot,\
                io.openems.edge.controller.api.mqtt;version=snapshot,\
                io.openems.edge.controller.api.rest;version=snapshot,\
                io.openems.edge.controller.api.websocket;version=snapshot,\
                io.openems.edge.controller.asymmetric.balancingcosphi;version=snapshot,\
                io.openems.edge.controller.asymmetric.fixreactivepower;version=snapshot,\
                io.openems.edge.controller.asymmetric.peakshaving;version=snapshot,\
                io.openems.edge.controller.asymmetric.phaserectification;version=snapshot,\
                io.openems.edge.controller.channelthreshold;version=snapshot,\
                io.openems.edge.controller.chp.soc;version=snapshot,\
                io.openems.edge.controller.debug.detailedlog;version=snapshot,\
                io.openems.edge.controller.debug.log;version=snapshot,\
                io.openems.edge.controller.ess.acisland;version=snapshot,\
                io.openems.edge.controller.ess.activepowervoltagecharacteristic;version=snapshot,\
                io.openems.edge.controller.ess.balancing;version=snapshot,\
                io.openems.edge.controller.ess.cycle;version=snapshot,\
                io.openems.edge.controller.ess.delaycharge;version=snapshot,\
                io.openems.edge.controller.ess.delayedselltogrid;version=snapshot,\
                io.openems.edge.controller.ess.emergencycapacityreserve;version=snapshot,\
                io.openems.edge.controller.ess.fixactivepower;version=snapshot,\
                io.openems.edge.controller.ess.fixstateofcharge;version=snapshot,\
                io.openems.edge.controller.ess.gridoptimizedcharge;version=snapshot,\
                io.openems.edge.controller.ess.hybrid.surplusfeedtogrid;version=snapshot,\
                io.openems.edge.controller.ess.limittotaldischarge;version=snapshot,\
                io.openems.edge.controller.ess.linearpowerband;version=snapshot,\
                io.openems.edge.controller.ess.mindischargeperiod;version=snapshot,\
                io.openems.edge.controller.ess.reactivepowervoltagecharacteristic;version=snapshot,\
                io.openems.edge.controller.ess.selltogridlimit;version=snapshot,\
                io.openems.edge.controller.ess.standby;version=snapshot,\
                io.openems.edge.controller.ess.timeofusetariff;version=snapshot,\
                io.openems.edge.controller.evcs;version=snapshot,\
                io.openems.edge.controller.evcs.fixactivepower;version=snapshot,\
                io.openems.edge.controller.generic.jsonlogic;version=snapshot,\
                io.openems.edge.controller.highloadtimeslot;version=snapshot,\
                io.openems.edge.controller.io.alarm;version=snapshot,\
                io.openems.edge.controller.io.analog;version=snapshot,\
                io.openems.edge.controller.io.channelsinglethreshold;version=snapshot,\
                io.openems.edge.controller.io.fixdigitaloutput;version=snapshot,\
                io.openems.edge.controller.io.heatingelement;version=snapshot,\
                io.openems.edge.controller.io.heatpump.sgready;version=snapshot,\
                io.openems.edge.controller.pvinverter.fixpowerlimit;version=snapshot,\
                io.openems.edge.controller.pvinverter.selltogridlimit;version=snapshot,\
                io.openems.edge.controller.symmetric.balancingschedule;version=snapshot,\
                io.openems.edge.controller.symmetric.fixreactivepower;version=snapshot,\
                io.openems.edge.controller.symmetric.limitactivepower;version=snapshot,\
                io.openems.edge.controller.symmetric.peakshaving;version=snapshot,\
                io.openems.edge.controller.symmetric.randompower;version=snapshot,\
                io.openems.edge.controller.symmetric.timeslotpeakshaving;version=snapshot,\
                io.openems.edge.core;version=snapshot,\
                io.openems.edge.edge2edge;version=snapshot,\
                io.openems.edge.energy;version=snapshot,\
                io.openems.edge.energy.api;version=snapshot,\
                io.openems.edge.ess.adstec.storaxe;version=snapshot,\
                io.openems.edge.ess.api;version=snapshot,\
                io.openems.edge.ess.byd.container;version=snapshot,\
                io.openems.edge.ess.cluster;version=snapshot,\
                io.openems.edge.ess.core;version=snapshot,\
                io.openems.edge.ess.fenecon.commercial40;version=snapshot,\
                io.openems.edge.ess.generic;version=snapshot,\
                io.openems.edge.ess.mr.gridcon;version=snapshot,\
                io.openems.edge.ess.samsung;version=snapshot,\
                io.openems.edge.ess.sma;version=snapshot,\
                io.openems.edge.evcs.alpitronic.hypercharger;version=snapshot,\
                io.openems.edge.evcs.api;version=snapshot,\
                io.openems.edge.evcs.cluster;version=snapshot,\
                io.openems.edge.evcs.core;version=snapshot,\
                io.openems.edge.evcs.dezony;version=snapshot,\
                io.openems.edge.evcs.goe.chargerhome;version=snapshot,\
                io.openems.edge.evcs.hardybarth;version=snapshot,\
                io.openems.edge.evcs.keba.kecontact;version=snapshot,\
                io.openems.edge.evcs.ocpp.abl;version=snapshot,\
                io.openems.edge.evcs.ocpp.common;version=snapshot,\
                io.openems.edge.evcs.ocpp.ies.keywatt.singleccs;version=snapshot,\
                io.openems.edge.evcs.ocpp.server;version=snapshot,\
                io.openems.edge.evcs.spelsberg;version=snapshot,\
                io.openems.edge.evcs.webasto.next;version=snapshot,\
                io.openems.edge.evcs.webasto.unite;version=snapshot,\
                io.openems.edge.fenecon.dess;version=snapshot,\
                io.openems.edge.fenecon.mini;version=snapshot,\
                io.openems.edge.fenecon.pro;version=snapshot,\
                io.openems.edge.goodwe;version=snapshot,\
                io.openems.edge.io.api;version=snapshot,\
                io.openems.edge.io.filipowski;version=snapshot,\
                io.openems.edge.io.gpio;version=snapshot,\
                io.openems.edge.io.kmtronic;version=snapshot,\
                io.openems.edge.io.offgridswitch;version=snapshot,\
                io.openems.edge.io.revpi;version=snapshot,\
                io.openems.edge.io.shelly;version=snapshot,\
                io.openems.edge.io.wago;version=snapshot,\
                io.openems.edge.io.weidmueller;version=snapshot,\
                io.openems.edge.kaco.blueplanet.hybrid10;version=snapshot,\
                io.openems.edge.katek.edcom;version=snapshot,\
                io.openems.edge.kostal.piko;version=snapshot,\
                io.openems.edge.meter.abb;version=snapshot,\
                io.openems.edge.meter.api;version=snapshot,\
                io.openems.edge.meter.artemes.am2;version=snapshot,\
                io.openems.edge.meter.bcontrol.em300;version=snapshot,\
                io.openems.edge.meter.bgetech;version=snapshot,\
                io.openems.edge.meter.camillebauer.aplus;version=snapshot,\
                io.openems.edge.meter.carlo.gavazzi.em300;version=snapshot,\
                io.openems.edge.meter.discovergy;version=snapshot,\
                io.openems.edge.meter.eastron;version=snapshot,\
                io.openems.edge.meter.janitza;version=snapshot,\
                io.openems.edge.meter.kdk;version=snapshot,\
                io.openems.edge.meter.phoenixcontact;version=snapshot,\
                io.openems.edge.meter.plexlog;version=snapshot,\
                io.openems.edge.meter.pqplus;version=snapshot,\
                io.openems.edge.meter.schneider.acti9.smartlink;version=snapshot,\
                io.openems.edge.meter.siemens;version=snapshot,\
                io.openems.edge.meter.sma.shm20;version=snapshot,\
                io.openems.edge.meter.socomec;version=snapshot,\
                io.openems.edge.meter.sunspec;version=snapshot,\
                io.openems.edge.meter.virtual;version=snapshot,\
                io.openems.edge.meter.weidmueller;version=snapshot,\
                io.openems.edge.meter.ziehl;version=snapshot,\
                io.openems.edge.onewire.thermometer;version=snapshot,\
                io.openems.edge.predictor.api;version=snapshot,\
                io.openems.edge.predictor.persistencemodel;version=snapshot,\
                io.openems.edge.predictor.similardaymodel;version=snapshot,\
                io.openems.edge.pvinverter.api;version=snapshot,\
                io.openems.edge.pvinverter.cluster;version=snapshot,\
                io.openems.edge.pvinverter.fronius;version=snapshot,\
                io.openems.edge.pvinverter.kaco.blueplanet;version=snapshot,\
                io.openems.edge.pvinverter.kostal;version=snapshot,\
                io.openems.edge.pvinverter.sma;version=snapshot,\
                io.openems.edge.pvinverter.solarlog;version=snapshot,\
                io.openems.edge.pvinverter.sunspec;version=snapshot,\
                io.openems.edge.scheduler.allalphabetically;version=snapshot,\
                io.openems.edge.scheduler.api;version=snapshot,\
                io.openems.edge.scheduler.daily;version=snapshot,\
                io.openems.edge.scheduler.fixedorder;version=snapshot,\
                io.openems.edge.simulator;version=snapshot,\
                io.openems.edge.solaredge;version=snapshot,\
                io.openems.edge.tesla.powerwall2;version=snapshot,\
                io.openems.edge.thermometer.api;version=snapshot,\
                io.openems.edge.timedata.api;version=snapshot,\
                io.openems.edge.timedata.influxdb;version=snapshot,\
                io.openems.edge.timedata.rrd4j;version=snapshot,\
                io.openems.edge.timeofusetariff.api;version=snapshot,\
                io.openems.edge.timeofusetariff.awattar;version=snapshot,\
                io.openems.edge.timeofusetariff.corrently;version=snapshot,\
                io.openems.edge.timeofusetariff.entsoe;version=snapshot,\
                io.openems.edge.timeofusetariff.groupe;version=snapshot,\
                io.openems.edge.timeofusetariff.hassfurt;version=snapshot,\
                io.openems.edge.timeofusetariff.rabotcharge;version=snapshot,\
                io.openems.edge.timeofusetariff.tibber;version=snapshot,\
                io.openems.oem.openems;version=snapshot,\
                io.openems.shared.influxdb;version=snapshot,\
                io.openems.wrapper.eu.chargetime.ocpp;version=snapshot,\
                io.openems.wrapper.fastexcel;version=snapshot,\
                io.openems.wrapper.gson;version=snapshot,\
                io.openems.wrapper.influxdb-client-core;version=snapshot,\
                io.openems.wrapper.influxdb-client-java;version=snapshot,\
                io.openems.wrapper.influxdb-client-utils;version=snapshot,\
                io.openems.wrapper.influxdb-flux-dsl;version=snapshot,\
                io.openems.wrapper.io.reactivex.rxjava3.rxjava;version=snapshot,\
                io.openems.wrapper.javax.activation;version=snapshot,\
                io.openems.wrapper.jenetics;version=snapshot,\
                io.openems.wrapper.kotlinx-coroutines-core-jvm;version=snapshot,\
                io.openems.wrapper.okhttp;version=snapshot,\
                io.openems.wrapper.opczip;version=snapshot,\
                io.openems.wrapper.paho-mqttv5;version=snapshot,\
                io.openems.wrapper.retrofit-adapter-rxjava3;version=snapshot,\
                io.openems.wrapper.retrofit-converter-gson;version=snapshot,\
                io.openems.wrapper.retrofit-converter-scalars;version=snapshot,\
                io.openems.wrapper.retrofit2;version=snapshot,\
                io.openems.wrapper.sdnotify;version=snapshot,\
                io.reactivex.rxjava3.rxjava;version='[3.1.8,3.1.9)',\
                javax.jmdns;version='[3.4.1,3.4.2)',\
                javax.xml.soap-api;version='[1.4.0,1.4.1)',\
                org.apache.commons.commons-csv;version='[1.10.0,1.10.1)',\
                org.apache.commons.math3;version='[3.6.1,3.6.2)',\
                org.apache.felix.configadmin;version='[1.9.26,1.9.27)',\
                org.apache.felix.eventadmin;version='[1.6.4,1.6.5)',\
                org.apache.felix.fileinstall;version='[3.7.4,3.7.5)',\
                org.apache.felix.http.jetty;version='[5.1.22,5.1.23)',\
                org.apache.felix.http.servlet-api;version='[3.0.0,3.0.1)',\
                org.apache.felix.inventory;version='[2.0.0,2.0.1)',\
                org.apache.felix.metatype;version='[1.2.4,1.2.5)',\
                org.apache.felix.scr;version='[2.2.12,2.2.13)',\
                org.apache.felix.webconsole;version='[5.0.4,5.0.5)',\
                org.apache.felix.webconsole.plugins.ds;version='[2.3.0,2.3.1)',\
                org.eclipse.jetty.client;version='[9.4.28,9.4.29)',\
                org.eclipse.jetty.http;version='[9.4.28,9.4.29)',\
                org.eclipse.jetty.io;version='[9.4.28,9.4.29)',\
                org.eclipse.jetty.util;version='[9.4.28,9.4.29)',\
                org.eclipse.paho.mqttv5.client;version='[1.2.5,1.2.6)',\
                org.jetbrains.kotlin.osgi-bundle;version='[2.0.0,2.0.1)',\
                org.jsoup;version='[1.17.2,1.17.3)',\
                org.jsr-305;version='[3.0.2,3.0.3)',\
                org.openmuc.jmbus;version='[3.3.0,3.3.1)',\
                org.openmuc.jrxtx;version='[1.0.1,1.0.2)',\
                org.ops4j.pax.logging.pax-logging-api;version='[2.2.1,2.2.2)',\
                org.ops4j.pax.logging.pax-logging-log4j2;version='[2.2.1,2.2.2)',\
                org.osgi.service.component;version='[1.5.1,1.5.2)',\
                org.osgi.util.function;version='[1.2.0,1.2.1)',\
                org.osgi.util.promise;version='[1.3.0,1.3.1)',\
                org.owasp.encoder;version='[1.2.3,1.2.4)',\
                reactive-streams;version='[1.0.4,1.0.5)',\
                rrd4j;version='[3.9.0,3.9.1)'
-resolve: manual
I was able to solve this final issue. The resolution was not working because for some reason in io.openems.edge.application/EdgeApp.bndrun under the Core Runtime dropdown, my Execution Environment was set as JavaSE-16 instead of JavaSE-17. I’m not sure why this was because I definitely did not change any of my settings…
