I am trying to add a Gridcon PCS settings, once I do this I got the following error
java.lang.IllegalArgumentException: The following BooleanWriteChannels have no Write-Value: gridcon2/CommandControlWordModeSelection,gridcon2/CommandControlWordTriggerSia,gridcon2/CommandControlWordFundamentalFrequencyModeBit1,gridcon2/CommandControlWordFundamentalFrequencyModeBit2,gridcon2/CommandControlWordBalancingModeBit1,gridcon2/CommandControlWordBalancingModeBit2,gridcon2/CommandControlWordHarmonicCompensationModeBit1,gridcon2/CommandControlWordHarmonicCompensationModeBit2
at io.openems.edge.bridge.modbus.api.element.BitsWordElement.getNextWriteValueAndReset(BitsWordElement.java:192)
at io.openems.edge.bridge.modbus.api.task.FC16WriteRegistersTask.mergeWriteRegisters(FC16WriteRegistersTask.java:124)
at io.openems.edge.bridge.modbus.api.task.FC16WriteRegistersTask._execute(FC16WriteRegistersTask.java:62)
at io.openems.edge.bridge.modbus.api.task.AbstractTask.execute(AbstractTask.java:82)
at io.openems.edge.bridge.modbus.api.ModbusWorker.forever(ModbusWorker.java:172)
at io.openems.common.worker.AbstractWorker$1.run(AbstractWorker.java:112)
Is the config available on the github repository, for the example?
