Help with Frontend Widget Configuration (Admin Access Issue)
I’m setting up OpenEMS and need help configuring the frontend widgets. Here’s my current setup and issue:
  • Backend: Running via Docker
  • Frontend: Angular application (separate instance)
  • Login Attempt: Using admin/admin credentials, but I’m only getting Guest access
  • Expected: Admin dashboard with widget configuration options
  • Actual: Limited guest view without widget management features
I’ve checked the documentation but couldn’t find specific instructions for:
  • Obtaining admin privileges after installation
  • Accessing the widget management interface
Thank you in advance for your support!
What do you mean with “Widget Management Interface” ? We do not have that.
how can I choose frontend visual component to be showed in live and history view?
Thanks
Thanks, I have to use password field as username (guest or admin)
sorry, i dont understand what you want/need/mean..
