NnT
March 15, 2024, 9:48am
1
I have simulated the grid system by adding the symmetric ESS and I want to explore how to change the ESS operation, I experiment by adding the controller by fix active power and It work if I set by UI approach but I try to use the REST API approch, I found that the value have fix value from UI setting and the the value channel set in the READ ONLY mode that I cannot POST the new values my questions is
Why the property value is set in the read only mode ?
If possible to set the controller by REST API ?
Sn0w3y
March 16, 2024, 12:48pm
2
Do you already have added the Controller Rest JSON Read/Write or only the Rest JSON Read ?
NnT
March 18, 2024, 4:06am
5
these are simulator components in my system.
Hi @NnT ,
I understand that your aim is to provide a set-point to an ESS, i.e. you want to send a charge/discharge command to an ESS from Python. Correct?
You have two options:
1. Via a Fix Active-Power Controller
This is what you are currently trying. In order to provide a new set-point, you have to reconfigure the Controller. Till now you were doing that via Apache Felix, but you can also do this via the JSON/REST-Api. See → Configuration :: Open Energy Management System → updateComponentConfig and → Controller :: Open Energy Management System
If you plan to send new set-points regularly - e.g. once per second, you should go for option 2:
2. Via SetActivePowerEquals Channel
With this approach you are directly setting the WriteChannel on the ESS. Follow the documentation here → Controller :: Open Energy Management System .
There is also a good documentation by FENECON, which applies to OpenEMS Edge as well → REST/JSON - Lese-/Schreibzugriff :: FENECON Dokumente
NnT
March 21, 2024, 8:57am
7
Oh, Thank you so much ! I’ve been stuck in this issue for almost a week, now I can update the new set point by outside (via Python scripts).
