Info about json format for ancillary costs in timeOfUseTarrif entsoe
I did find the component Time-Of-Use Tariff ENTSO-E in the UI. I’m wondering how to configure it. It expects as a mandatory field a json string for ancillary costs. I did find below code, where the string seems to get parsed. Unfortunately I fail to understand the format of the expected json string. Could someone give me an example or hint to some documentation, how the json string is expected to look like? Thanks in advance!
It is there.
sry, can you elaborate? I don’t find information about the structure of the json file.
Hi @sjjh,
the feature for ancillary costs is designed (for Germany) to support two different ways of providing the additional costs. In Germany those “zeitvariable Netzentgelte” are provided by the DSOs in “Preisblätter”.
  1. Predefined Costs in the GermanDSO enum → openems/io.openems.edge.timeofusetariff.entsoe/src/io/openems/edge/timeofusetariff/entsoe/GermanDSO.java at develop · OpenEMS/openems · GitHub
    This is the preferred way as it avoids errors. Together with the community we plan to hold an updated list of costs of most German DSOs here. By providing them as code we can do some automated validation and tests.
    If your DSO is already in the list (and the data is up-to-date), you can simply activate the costs by configuring TimeOfUseTariff.ENTSO-E with:
  1. Define the costs via manual JSON configuration.
    This is unfortunately not yet supported. See openems/io.openems.edge.timeofusetariff.entsoe/src/io/openems/edge/timeofusetariff/entsoe/AncillaryCosts.java at develop · OpenEMS/openems · GitHub
Hope this helps. As this is still a quite new feature I am happy to receive feedback.
(@venu-sagar FYI)
In German: ein paar Hintergrundinformationen warum wir dieses Feature für FEMS implementiert haben, zeige ich in diesem Video:
I did find the Preisblatt of our DSO Netze ODR:
Netze ODR is not yet in the list. The PDF contains different price information. Can you give me a hint which one is the relevant one? I’ll then happily try to provide a PR.
Thanks!
The relevant data for your DSO is on page 4:
You should then convert those dates and prices (“Arbeitspreis Brutto”) to DateRanges in GermanDSO.
I wasn’t sure, if I had to add any other prices from other tables to it… :confused:
So I created a PR (first on code in this repo), please review: Update GermanDSO.java: added DSO Netze ODR by sjjh · Pull Request #3224 · OpenEMS/openems · GitHub. :slight_smile:
Thanks!
Thanks for the explanation. Great feature.
I believe, especially if the community gets bigger and more end users (less developers) use it, the two use cases of how to add new DSOs and update (yearly – if I understood correctly) prices could maybe made easier. I could imagine some web form to add these data, either on openems.io or maybe embedded in the OpenEMS UI. The UI should IMHO automatically pull updates if the time frame of the data ends, and maybe a manual refresh via a button/trigger is sensible, e.g., on first initialization, in case a before missing DSO is included, or if the user changes their DSO (moving).
The selection of the DSO could be made easier by offering a drop-down with all available DSOs in the component in the OpenEMS UI. As soon as it is implemented to manually add a json string, the drop-down could include an element otherwhich would enable a free text field (ideally with either a dummy blueprint or some context help)
So far feedback from a first time user. :slight_smile:
Dear @sjjh ,
That’s amazing! We were thinking along the same lines and have already started working on this. The implementation is currently in progress, though everything is still local for now. Once it’s ready, I’ll link it to the PR. In the meantime, you can check out the progress through the attached screenshots.
Note: there are still some adjustments here and there, but final version would look something close to this.
Thank you,
Sagar
Cool, looks great. I could imagine adding a String name to the DSO enum, to make it look a little bit less technical. E.g., displaying SH Netz instead of SH_NETZ to the user in the drop-down (this could also enable l10n, OTHER → anderer). For the price items, I might be wondering if VAT should be included or not, adding brutto to the label could avoid this question.
Not sure about the logic in the background – if a new entry is added by a user, it obviously would be great to push it upstream and distribute it to other users. I don’t know enough about the domain, but it seems that typically the prices are only valid for a year. Thus I could imagine, that it would be interesting to:
  • remind users to update their prices at the end of the year
  • offer an update of prices independently of OpenEMS update
BTW, I think the UI of the drop-downs could be improved in general. In landscape mode adding a max-width (e.g., 80 em) could improve the usability a bit. But that’s unrelated to the entsoe implementation. :slight_smile:
Thanks for your work!
Simon
FYI: the JSON parser for custom ancilliary costs has been merged with
This has been implemented as well.
Hi All,
It would be great if an additional field could be implemented: the additional fix surcharge that the energy supplier charges per kw/h. Then the real price would be taken into account.
Hi @HeFa,
yes - ultimately the ENTSO-E Time-of-use-Tariff provider should then reflect the real gross price, i.e. the price that the customer really has to pay on his invoice.
Unfortunately calculating that price is not so easy - for Germany, and even more for Europe/the world. As you seem to have deeper knowledge on the topic: Could you suggest the actual fields, their descriptions (e.g. in App Center) and calculation formula?
Thanks in advance!
Hi!
I’m sorry to bring up this older topic, but I wanted to ask if there is any progress on this?
There are a lot of different formulas to calculate the actual price, I’m sure, so I can give you my 2 calculations if it helps:
Grid buying: ((1.04 * price) + 0.50) c€/kWh * 6%(VAT)
Grid selling: ((1 * price) - 0.98) c€/kWh (No VAT applies)
My provider doesn’t really specific what those values represent, but I have added them as follows in Home Assistant templates:
  • Price markup: The value which the spot price is multiplied by (1.04 and 1 in my case)
  • Fixed markup: The value that is added for each kWh, regardless of price (0.50 and -0.98 in my case)
  • VAT: Speaks for itself, optional VAT to be applied, for my case, VAT is only applied to buying from the grid
Thanks @Tommatheussen for bringing this up again. I had an internal PR which never got tested and finalized.
Would this solve your requirements - at least for “grid buy”?
Thanks for the quick reply @stefan.feilmeier !
Had a short look through the PR, I think that would indeed solve the case mostly, a great start nonetheless.
I haven’t gotten in depth yet on the dynamic tariff option in openEMS, especially around selling, but the formulas used by my provider mostly show the buying and selling curves following each other, with a little bit more penalty on the selling side.
