Hello OpenEMS Community,
I am facing an issue with modifying the balancing schedule in OpenEMS, and I’m seeking assistance in resolving it.
Problem Description:
I have set the balancing schedule parameter with the following values:
[ { “startTimestamp”: 1577836800, “duration”: 900, “activePowerSetPoint”: 0 }, { “startTimestamp”: 1577837700, “duration”: 900, “activePowerSetPoint”: -2000 }]
However, after saving the changes, I do not see any reflection of the modified schedule in the OpenEMS user interface.
Steps to Reproduce:
Access the OpenEMS UI.
Navigate to the “Balancing Schedule” section.
Modify the schedule parameter with the provided values.
Save the changes.
Expected Outcome:
I expect to see the modified balancing schedule reflected in the OpenEMS user interface.
What I’ve Tried:
I have cleared my browser cache and refreshed the page, but the changes are still not visible.
I tried to set the value by REST API, but without any result.
Additional Information:
When I tried to change the SOC of “ESSSymmetric Reacting” to 60%, the changes were immediately visible.
Logs:
[ctrlBackend0] Duplicate Key [“”]
2023-07-25T13:37:44,906 [_cycle ] INFO [ebuglog.ControllerDebugLogImpl] [ctrlDebugLog0] _sum[State:Fault Ess SoC:60 %|L:0 W Grid:1156 W Consumption:1156 W] ctrlApiRest0[State:FAULT: Unable to start REST-Api Server] ctrlBalancingSchedule0[State:INFO: No active Set-Point given] ess0[SoC:60 %|L:0 W|On-Grid] meter0[1156 W]
Any guidance or insights into why the changes are not reflected in the UI would be greatly appreciated. I am open to any suggestions or troubleshooting steps to resolve this issue.
Thank you for your time and assistance.
Best regards,
Razan Habeeb
