Hi guys,
i want to get started with the openEms project. But is there any good linux setup manual available?
When i follow the documentation i copy the git reposy in step 2
Getting Started :: Open Energy Management System (openems.github.io)
in the step 2 this seems only documented to run on windows?
can you guys put me in the correct direction?
Sure,
on Linux you can just do a
$ git clone https://github.com/OpenEMS/openems.git
and you do not need Sourcetree.
No, you can follow the exact steps in the guide to set up a development environment.
You also can build the edge and backend apps using gradle
without installing eclipse:
$ ./gradlew buildEdge
$ ./gradew buildBackend
I hope it is helpful for you.
Best.
Thanks!
Can i find this in the documentation somewhere?
no just take a look at build.gradle
file.
Best Regards
