I just set up odoo and Metadata.Odoo component in the backend server with all the necessary credentials, but in the terminal it doesn’t seem to be able to recognize the edge device connection to backend and it gave me this error:
2024-06-17T09:46:59,333 [thread-1] INFO [.debugcycle.DebugCycleExecutor] [Metadata.Odoo] [monitor] Default: Pool: 0/15, Pending: 0, Completed: 0, Active: 0, EdgeConfig: Pool: 0/15, Pending: 0, Completed: 0, Active: 0, Tasks:
2024-06-17T09:46:59,335 [thread-1] INFO [.debugcycle.DebugCycleExecutor] [Ui.Websocket] [monitor] Connections: 0, Pool: 0/10, Pending: 0, Completed: 0, Active: 0
2024-06-17T09:46:59,335 [thread-1] INFO [.debugcycle.DebugCycleExecutor] [Edge.Websocket] [monitor] Connections: 1, Pool: 10/10, Pending: 0, Completed: 617, Active: 0
java.lang.ClassCastException: class io.openems.backend.metadata.dummy.MyEdge cannot be cast to class io.openems.backend.metadata.odoo.MyEdge (io.openems.backend.metadata.dummy.MyEdge is in unnamed module of loader org.apache.felix.framework.BundleWiringImpl$BundleClassLoader @3c025fcd; io.openems.backend.metadata.odoo.MyEdge is in unnamed module of loader org.apache.felix.framework.BundleWiringImpl$BundleClassLoader @5231a31a)
at io.openems.backend.metadata.odoo.MetadataOdoo.handleEvent(MetadataOdoo.java:357) ~[?:?]
at org.apache.felix.eventadmin.impl.handler.EventHandlerProxy.sendEvent(EventHandlerProxy.java:432) ~[?:?]
at org.apache.felix.eventadmin.impl.tasks.HandlerTask.runWithoutDenylistTiming(HandlerTask.java:82) ~[?:?]
at org.apache.felix.eventadmin.impl.tasks.SyncDeliverTasks.execute(SyncDeliverTasks.java:107) ~[?:?]
at org.apache.felix.eventadmin.impl.handler.EventAdminImpl.sendEvent(EventAdminImpl.java:155) ~[?:?]
at org.apache.felix.eventadmin.impl.security.EventAdminSecurityDecorator.sendEvent(EventAdminSecurityDecorator.java:96) ~[?:?]
at io.openems.common.event.EventBuilder.send(EventBuilder.java:80) ~[?:?]
at io.openems.backend.common.metadata.Edge.setLastmessage(Edge.java:146) ~[?:?]
at io.openems.backend.common.metadata.Edge.setLastmessage(Edge.java:134) ~[?:?]
at io.openems.backend.common.metadata.Edge.setLastmessage(Edge.java:124) ~[?:?]
at io.openems.backend.edgewebsocket.OnNotification.lambda$0(OnNotification.java:52) ~[?:?]
at java.util.Optional.ifPresent(Optional.java:178) ~[?:?]
at io.openems.backend.edgewebsocket.OnNotification.run(OnNotification.java:51) ~[?:?]
at io.openems.common.websocket.OnNotificationHandler.run(OnNotificationHandler.java:22) ~[?:?]
at io.openems.common.websocket.AbstractWebsocketServer.lambda$3(AbstractWebsocketServer.java:332) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:?]
at java.lang.Thread.run(Thread.java:840) ~[?:?]
How do I fix this?
