Greetings, I am a complete newbie with your system. I need help with connecting Modbus RTU devices, specifically the Deye SUN-12K inverter. I have seen detailed instructions via IDE and as I understand not yet built version of Openems edge.
Is it possible to replicate this using the pre-built version from Github? If so, I would be very grateful for the instructions.
My setup:
Raspberry Pi 4 with Openems edge installed and connected RS485 to USB adapter
Windows server with Openems Backend + UI installed
I have a file with all Modbus registers and settings that I have successfully checked through the console
Also on the forum I read that someone has already connected this inverter
Here is a link to the thread: Implementation DEYE Inverter - Approach - #5 by Rayleigh3105
But I didn’t understand if everything worked out and how to use these developments correctly. Anyway I want to get experience in adding custom Modbus devices
I would be grateful for any advice.
