Hey everyone, I’m using Modbus TCP to connect to my inverter. However, I’m receiving message about refused connection.
My debug log:
Execute failed FC3ReadHoldingRegisters [batteryInverter0;unitid=1;priority=HIGH;ref=0/0x0;length=28] OpenemsException: Connection to [192.168.1.121] failed: Connection refused
The channels I have declared in my inverter:
@Override
protected ModbusProtocol defineModbusProtocol() {
return new ModbusProtocol(this, //
new FC3ReadRegistersTask(0, Priority.HIGH, //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.GRID_VOLTAGE_L1, new FloatDoublewordElement(0)), //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.GRID_VOLTAGE_L2, new FloatDoublewordElement(2)), //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.GRID_VOLTAGE_L3, new FloatDoublewordElement(4)), //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.GRID_CURRENT_L1, new FloatDoublewordElement(6)), //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.GRID_CURRENT_L2, new FloatDoublewordElement(8)), //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.GRID_CURRENT_L3, new FloatDoublewordElement(10)), //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.FREQUENCY, new FloatDoublewordElement(12)), //
m(SymmetricBatteryInverter.ChannelId.ACTIVE_POWER, new FloatDoublewordElement(14)), //
m(SymmetricBatteryInverter.ChannelId.REACTIVE_POWER, new FloatDoublewordElement(16)), //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.APPARENT_POWER_TOTAL, new FloatDoublewordElement(18)), //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.COS_PHI, new FloatDoublewordElement(20)), //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.TEMPERATURE_OF_AC_HEAT_SINK, new FloatDoublewordElement(22)), // m(BatteryInverterApsEnergiaBfi2z.ChannelId.FREQUENCY, new FloatDoublewordElement(12)), //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.DC_VOLTAGE, new FloatDoublewordElement(24)), //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.DC_CURRENT, new FloatDoublewordElement(26))), //
new FC3ReadRegistersTask(28, Priority.LOW, //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.CHARGE_MAX_CURRENT_READ, new FloatDoublewordElement(28)), //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.DISCHARGE_MAX_CURRENT_READ, new FloatDoublewordElement(30)) //
new FC3ReadRegistersTask(300, Priority.LOW, //
// m(BatteryInverterApsEnergiaBfi2z.ChannelId.CHARGE_MAX_CURRENT, new FloatDoublewordElement(306)), //
// m(BatteryInverterApsEnergiaBfi2z.ChannelId.DISCHARGE_MAX_CURRENT, new FloatDoublewordElement(308)), //
// m(BatteryInverterApsEnergiaBfi2z.ChannelId.DISCHARGE_MIN_VOLTAGE, new FloatDoublewordElement(310)), //
// m(BatteryInverterApsEnergiaBfi2z.ChannelId.CHARGE_MAX_VOLTAGE, new FloatDoublewordElement(312)), //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.SET_ACTIVE_POWER, new FloatDoublewordElement(300)), //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.SET_REACTIVE_POWER, new FloatDoublewordElement(302)), //
// m(BatteryInverterApsEnergiaBfi2z.ChannelId.SET_OFF_GRID_FREQUENCY, new FloatDoublewordElement(318)), //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.START_INVERTER, new UnsignedWordElement(304)), //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.STOP_INVERTER, new UnsignedWordElement(305)), //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.CLEAR_FAILURE, new UnsignedWordElement(306)) //
// m(BatteryInverterApsEnergiaBfi2z.ChannelId.SET_ON_GRID_MODE, new UnsignedWordElement(323)), //
// m(BatteryInverterApsEnergiaBfi2z.ChannelId.SET_OFF_GRID_MODE, new UnsignedWordElement(324), INVERT_BOOLEAN) //
new FC3ReadRegistersTask(308, Priority.LOW, //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.CHARGE_MAX_CURRENT, new FloatDoublewordElement(308)), //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.DISCHARGE_MAX_CURRENT, new FloatDoublewordElement(310)), //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.DISCHARGE_MIN_VOLTAGE, new FloatDoublewordElement(312)), //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.CHARGE_MAX_VOLTAGE, new FloatDoublewordElement(314)) //
new FC3ReadRegistersTask(318, Priority.LOW, //
new FC3ReadRegistersTask(323, Priority.LOW, //
new FC16WriteRegistersTask(300, //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.SET_ACTIVE_POWER, new FloatDoublewordElement(300))),
new FC16WriteRegistersTask(302, //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.SET_REACTIVE_POWER, new FloatDoublewordElement(302))),
new FC16WriteRegistersTask(304, //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.START_INVERTER, new UnsignedWordElement(304))),
new FC16WriteRegistersTask(305, //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.STOP_INVERTER, new UnsignedWordElement(305))),
new FC16WriteRegistersTask(306, //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.CLEAR_FAILURE, new UnsignedWordElement(306))),
new FC16WriteRegistersTask(307, //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.HEART_BEAT, new UnsignedWordElement(307))),
new FC16WriteRegistersTask(308, //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.CHARGE_MAX_CURRENT, new SignedWordElement(308))),
new FC16WriteRegistersTask(310, //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.DISCHARGE_MAX_CURRENT, new SignedWordElement(310))),
new FC16WriteRegistersTask(312, //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.DISCHARGE_MIN_VOLTAGE, new SignedWordElement(312))),
new FC16WriteRegistersTask(314, //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.CHARGE_MAX_VOLTAGE, new SignedWordElement(314))),
new FC16WriteRegistersTask(318, //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.SET_OFF_GRID_FREQUENCY, new SignedWordElement(318))),
new FC16WriteRegistersTask(323, //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.SET_ON_GRID_MODE, new UnsignedWordElement(323))),
new FC16WriteRegistersTask(324, //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.SET_OFF_GRID_MODE, new UnsignedWordElement(324), INVERT_BOOLEAN)),
new FC16WriteRegistersTask(325, //
m(BatteryInverterApsEnergiaBfi2z.ChannelId.OFF_GRID_BLACKSTART_MODE, new UnsignedWordElement(325)))
If I get rid of some of them the connection works. Could it be that there is something wrong with the declaration?
Following declartion works without a problem:
// new FC16WriteRegistersTask(306, //
// m(BatteryInverterApsEnergiaBfi2z.ChannelId.CHARGE_MAX_CURRENT, new SignedWordElement(306))),
// new FC16WriteRegistersTask(308, //
// m(BatteryInverterApsEnergiaBfi2z.ChannelId.DISCHARGE_MAX_CURRENT, new SignedWordElement(308))),
// new FC16WriteRegistersTask(310, //
// m(BatteryInverterApsEnergiaBfi2z.ChannelId.DISCHARGE_MIN_VOLTAGE, new SignedWordElement(310))),
// new FC16WriteRegistersTask(312, //
// m(BatteryInverterApsEnergiaBfi2z.ChannelId.CHARGE_MAX_VOLTAGE, new SignedWordElement(312))),
// new FC16WriteRegistersTask(318, //
// m(BatteryInverterApsEnergiaBfi2z.ChannelId.SET_OFF_GRID_FREQUENCY, new SignedWordElement(318))),
// new FC16WriteRegistersTask(323, //
// m(BatteryInverterApsEnergiaBfi2z.ChannelId.SET_ON_GRID_MODE, new UnsignedWordElement(323))),
// new FC16WriteRegistersTask(324, //
// m(BatteryInverterApsEnergiaBfi2z.ChannelId.SET_OFF_GRID_MODE, new UnsignedWordElement(324), INVERT_BOOLEAN)),
// new FC16WriteRegistersTask(325, //
// m(BatteryInverterApsEnergiaBfi2z.ChannelId.OFF_GRID_BLACKSTART_MODE, new UnsignedWordElement(325)))
