Hello! I finished the Getting Started Guide, but I am having problems with the UI working with Backend. It is not whowing anything at all and basically sending this message:
In the logs I get in eclypse there is a warning that stands up:
.576 [_cycle] INFO io.openems.edge.controller.debuglog.ControllerDebugLogImpl - [ctrlDebugLog0] _sum[State:Warning Ess SoC:38 %|L:1553 W Grid:191 W Consumption:1744 W] ctrlBackend0[State:WARNING: UnableToSend] ess0[SoC:38 %|L:1553 W|Allowed:-10000;10000 W] meter0[191 W]
java.util.concurrent.ExecutionException: io.openems.common.exceptions.OpenemsError$OpenemsNamedException: No AppCenter Metadata provided.
at java.base/java.util.concurrent.CompletableFuture.reportGet(CompletableFuture.java:396)
at java.base/java.util.concurrent.CompletableFuture.get(CompletableFuture.java:2073)
at io.openems.edge.core.appmanager.AppCenterBackendUtilImpl.handleRequest(AppCenterBackendUtilImpl.java:107)
at io.openems.edge.core.appmanager.AppCenterBackendUtilImpl.getInstalledApps(AppCenterBackendUtilImpl.java:87)
at io.openems.edge.core.appmanager.AppSynchronizeWorker.syncAppsWithBackend(AppSynchronizeWorker.java:56)
at io.openems.edge.core.appmanager.AppSynchronizeWorker.forever(AppSynchronizeWorker.java:44)
at io.openems.common.worker.AbstractWorker$1.run(AbstractWorker.java:154)
Caused by: io.openems.common.exceptions.OpenemsError$OpenemsNamedException: No AppCenter Metadata provided.
at io.openems.common.websocket.WsData.handleJsonrpcResponse(WsData.java:131)
at io.openems.common.websocket.OnResponseHandler.run(OnResponseHandler.java:23)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
at java.base/java.lang.Thread.run(Thread.java:833)
The TCP ports seem to be ok, when I use the UI just with Edge everything works, but just not with Backend. I double checked the whole guide but i haven found what i am doing wrong, could somebody help?
Thanks in advance ![]()
