OpenEMS Edge Java Crashes
Hello everyone,
I recently encountered the frequent issue of Java crashing after some hours when I run OpenEMS Edge.
It runs on a Windows Computer with 16 GB Ram. So far I only start OpenEMS-Edge in Eclipse.
Here is the Error-Message:
# A fatal error has been detected by the Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x70721b9c, pid=9045800, tid=9203716
# JRE version: OpenJDK Runtime Environment Temurin-17.0.8+7 (17.0.8+7) (build 17.0.8+7)
# Java VM: OpenJDK Client VM Temurin-17.0.8+7 (17.0.8+7, mixed mode, emulated-client, serial gc, windows-x86)
# Problematic frame:
# V  [jvm.dll+0x381b9c]
# No core dump will be written. Minidumps are not enabled by default on client versions of Windows
“Problematic frame” is always something different and can also be simple Exceptions because of a missing component.
Does anyone had same experiences? Does anyone has a clue what causes this error and how to solve it?
Many thanks in advance!
Regards
Alex
Did you try running it with Java 21 as recommended?..
In the mean time I found that it only appears if windows RAM is almost full. Somehow windows fills its RAM over one week from 40% to almost 90%. When rebooting frequently it does not happen. I consider switching to windows server.
PS: Switching to Java 21 did not help
