Highlights
- Improvements on energy values (#1187)
- Adjust driver components for GoodWe, Sinexcel, Carlo Gavazzi, KACO blueplanet gridsave, Janitza UMG96RME and all the Simulators
- Improve handling throughout the stack in OpenEMS Edge and OpenEMS UI
- Implement BMW battery (#1199)
- as used in the award winning FENECON Industrial energy storage platform
- Implement historic energy with local timeseries database RRD4J (#1198)
- Implement SOCOMEC Countis E23 meter 60519cc
Bug Fixes and Other Changes
- Fix BackendApp.bndrun: Update & resolve 7aa7be7
- Fix Backend-UI: Show ‘no edges’ warning only after connection was fully established c18f6dd
- Fix AbstractReadChannel: detection of changed values. This avoids unnecessary calls to the onChangeCallbacks 2f58826
- Fix StartStoppable: calls to start() and stop() fab676d
- Fix behaviour for optional configuration parameters f032667
- An optional configuration parameter is a parameter that is defined as ‘required = false’ within the @AttributeDefinition in Config.java.
Before the behaviour for optional ‘int’ parameters used to be, that they would default to ‘0’ if they were not provided. Now - maybe caused by an update to Apache Felix Configuration Admin - they default to an empty String which causes a NumberFormatException.
- Fix Controller.Api.Websocket: subscribe topic for event handler b019ee5
- Fixes the error on startup:
WARN [org.apache.felix.eventadmin ] EventAdmin: Invalid EVENT_TOPICS : Missing - Ignoring ServiceReference
- Fix Soltaro.Single.VersionA: implement SoltaroBattery interface 3ed6dac
- Fix RRD4j: fix last timestamp check
- Fix Generic.Ess: mixed up handlers for StopBatteryInverter and StopBattery cc8d30b
- Fix SDM630 meter: modbus registers 4988750
- Event Admin: disable timeout 0ffd25e
- Antora docs: update versions for dependencies 3497e23
