Highlights
- UI: add kWh as bar chart for energymonitor in history (#1250)
Fixes:
- remove deprecated npm packages
- update to latest npm packages
- adjust live energymonitor to be shown correctly
- replace ngOnInit with ionViewWillEnter in components where it is needed
(ngOnInit fires only once with ion-router-outlet, independently of visiting the component again)
Minor Features:
- set language on startup dependend of browser language
- remove redundancy in history energymonitor component
- better visibility for history energymonitor components legend
- show month when a month is picked via ‘other period’ in history component
- add real time detection that determines if user uses a device with smartphone resolution (<577px width)
- use whole width for history energymonitor component if smartphone resolution is used
Main Feature:
- if kWh are enabled via service component
- add bar chart for kWh values in history energymonitor
- bar chart shows energy per day including direct consumption
- on smartphone devices: kWh bar chart is enabled when period is > 1 day
- on non smartphone devices: kWh bar chart is enabled when period is > 7 days
- production and consumption values are opt in via legend
- realtime adjustment of chart when resolution changes from/to smartphone resolution
- add month to pickdate component
Bug Fixes and Other Changes
- Modbus/TCP and REST-Apis: log active write requests dfab9ef1fd583797f3213b7c43821780fcc28ff2
- Requests are logged in the new ApiWorker Channel as String of the form “ess0/SetActivePowerLessOrEquals:2000|ess0/SetActivePowerGreaterOrEquals:-2000”
- Generic ESS: improve calculation of allowed power(#1254)
- improve calculation of allowed charge/discharge power based on voltage
- add static constraints to block power, when ESS is not started
- Fix InfluxDB bundle and EdgeConfigWorker (possible NullPointerException) 768adc6df76dd2b3cb0e72d185fe1af3e89d26a8
- see also thread in OpenEMS Community Scheduler All Alphabetically - "cycle time" field is missing
- Fix XLSX report for Modbus/TCP Api 8ae8a579b350b934d9c167dbe043c22ac579d587
- UI: translated login page (#1257) - thanks @denis-jasselette-jc for your first contribution!
- GenericManagedSymmetricEss: add Modbus table for Modbus/TCP Api (#1262)
- Added the modbus slave table in generic Ess
- Changed the chargeEnergy and DichargeEnergy channels in battery inverter
- OpenemsComponent: add helpful error message on missing ‘State’ Channel (#1264)
- Update dependencies
