I have problems getting OpenEMS to work. I followed the steps under “Getting Started”, but after importing the project to Eclipse (step 2.2), I get about 50 errors and 200 warnings, mostly related to unresolvable types:
Eclipse Error Messages
Description Resource Path Location Type AbstractHandler cannot be resolved to a type RestHandler.java /io.openems.edge.controller.api.rest/src/io/openems/edge/controller/api/rest line 65 Java Problem AcceptRateLimit cannot be resolved to a type AbstractRestApi.java /io.openems.edge.controller.api.rest/src/io/openems/edge/controller/api/rest line 62 Java Problem Cannot find /error/org.apache.felix.http.jetty;version=0 Not found in [bnd-cache [C:/Users/Simon/git/openems/cnf/cache/5.2.0/bnd-cache r/w=false], BndPomRepository [name=OSGi R7 API, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-OSGi R7 API.xml], BndPomRepository [name=Enterprise Java APIs, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-Enterprise Java APIs.xml], BndPomRepository [name=Testing Bundles, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-Testing Bundles.xml], BndPomRepository [name=Maven Central, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-Maven Central.xml], Local, Templates, Release] bnd.bnd /io.openems.backend.b2brest line 6 Bndtools Path Problem Marker Cannot find /error/org.apache.felix.http.jetty;version=0 Not found in [bnd-cache [C:/Users/Simon/git/openems/cnf/cache/5.2.0/bnd-cache r/w=false], BndPomRepository [name=OSGi R7 API, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-OSGi R7 API.xml], BndPomRepository [name=Enterprise Java APIs, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-Enterprise Java APIs.xml], BndPomRepository [name=Testing Bundles, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-Testing Bundles.xml], BndPomRepository [name=Maven Central, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-Maven Central.xml], Local, Templates, Release] bnd.bnd /io.openems.edge.controller.api.rest line 6 Bndtools Path Problem Marker ConnectionLimit cannot be resolved to a type AbstractRestApi.java /io.openems.edge.controller.api.rest/src/io/openems/edge/controller/api/rest line 63 Java Problem org.apache.felix.http.jetty;version=0 Not found in [bnd-cache [C:/Users/Simon/git/openems/cnf/cache/5.2.0/bnd-cache r/w=false], BndPomRepository [name=OSGi R7 API, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-OSGi R7 API.xml], BndPomRepository [name=Enterprise Java APIs, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-Enterprise Java APIs.xml], BndPomRepository [name=Testing Bundles, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-Testing Bundles.xml], BndPomRepository [name=Maven Central, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-Maven Central.xml], Local, Templates, Release] bnd.bnd /io.openems.backend.b2brest line 6 Bndtools Path Problem Marker org.apache.felix.http.jetty;version=0 Not found in [bnd-cache [C:/Users/Simon/git/openems/cnf/cache/5.2.0/bnd-cache r/w=false], BndPomRepository [name=OSGi R7 API, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-OSGi R7 API.xml], BndPomRepository [name=Enterprise Java APIs, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-Enterprise Java APIs.xml], BndPomRepository [name=Testing Bundles, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-Testing Bundles.xml], BndPomRepository [name=Maven Central, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-Maven Central.xml], Local, Templates, Release] bnd.bnd /io.openems.edge.controller.api.rest line 6 Bndtools Path Problem Marker Request cannot be resolved to a type RestHandler.java /io.openems.edge.controller.api.rest/src/io/openems/edge/controller/api/rest line 76 Java Problem […] Server cannot be resolved to a type AbstractRestApi.java /io.openems.edge.controller.api.rest/src/io/openems/edge/controller/api/rest line 35 Java Problem […] The import org.eclipse cannot be resolved AbstractRestApi.java /io.openems.edge.controller.api.rest/src/io/openems/edge/controller/api/rest line 5 Java Problem […] The project was not built since its build path is incomplete. Cannot find the class file for org.eclipse.jetty.util.Attributes. Fix the build path then try building this project io.openems.backend.b2brest Unknown Java Problem The type org.eclipse.jetty.util.Attributes cannot be resolved. It is indirectly referenced from required .class files B2bRest.java /io.openems.backend.b2brest/src/io/openems/backend/b2brest line 63 Java Problem Will not build project io.openems.backend.b2brest until the compilation and/or path problems are fixed, output files are kept. bnd.bnd /io.openems.backend.b2brest line 1 Bndtools Problem Marker Will not build project io.openems.edge.controller.api.rest until the compilation and/or path problems are fixed, output files are kept. bnd.bnd /io.openems.edge.controller.api.rest line 1 Bndtools Problem Marker Build path specifies execution environment JavaSE-1.8. There are no JREs installed in the workspace that are strictly compatible with this environment. io.openems.backend.application Build path JRE System Library Problem […] The method newInstance() from the type Class<capture#9-of ?> is deprecated OneWireAccessProvider.java /io.openems.edge.bridge.onewire/src/com/dalsemi/onewire line 285 Java Problem […] The compiler compliance specified is 1.8 but a JRE 14 is used io.openems.edge.controller.ess.limittotaldischarge Compiler Compliance JRE Compiler Compliance Problem […]
Two main problems striked me most:
- Eclipse cannot find the installed Jetty version
- Apparently, JRE 14 is in use, even though in Eclipse under Project / Properties / Java Build Path / Libraries it clearly says that JavaSE-1.8 is being used.
When using Gradle via the terminal instead, the problem is reduced to the Jetty version that cannot be found:
Gradle Error Messages
C:\Users\Simon\git\openems>gradlew.bat build -x test
> Task :io.openems.backend.b2brest:compileJava FAILED
error : Cannot find /error/org.apache.felix.http.jetty;version=0 Not found in [bnd-cache [C:/Users/Simon/git/openems/cnf/cache/5.0.0/bnd-cache r/w=false], BndPomRepository [name=OSGi R7 API, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-OSGi R7 API.xml, inited=true], BndPomRepository [name=Enterprise Java APIs, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-Enterprise Java APIs.xml, inited=true], BndPomRepository [name=Testing Bundles, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-Testing Bundles.xml, inited=true], BndPomRepository [name=Maven Central, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-Maven Central.xml, inited=true], Local, Templates, Release]
error : org.apache.felix.http.jetty;version=0 Not found in [bnd-cache [C:/Users/Simon/git/openems/cnf/cache/5.0.0/bnd-cache r/w=false], BndPomRepository [name=OSGi R7 API, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-OSGi R7 API.xml, inited=true], BndPomRepository [name=Enterprise Java APIs, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-Enterprise Java APIs.xml, inited=true], BndPomRepository [name=Testing Bundles, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-Testing Bundles.xml, inited=true], BndPomRepository [name=Maven Central, localRepo=C:\Users\Simon.m2\repository, location=cnf/cache/pom-Maven Central.xml, inited=true], Local, Templates, Release]FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ‘:io.openems.backend.b2brest:compileJava’.
> io.openems.backend.b2brest has errors, 2 errors were reported* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output. Run with --scan to get full insights.* Get more help at https://help.gradle.org
BUILD FAILED in 31s
16 actionable tasks: 14 executed, 2 up-to-date
Do you know about this problem or do you have some advice for me? Thanks a lot in advance!
