I created a proposal for changed getter and setter methods on OpenEMS Natures at Github:
OpenEMS Natures like SymmetricMeter declare the Channel-IDs that are to be provided by implementations of the Nature. The Nature interface also provides Java Getter methods to access the Channels, e.g. (Source)
/** * Gets the Active Power in [W]. Negative values for Consumption; positive for * Production * * @return the Channel */ default Channel<Integer> getActivePower() { return this.channel(ChannelId.ACTIVE_POWER); }
and (Source)
/** * Gets the Set Active Power Equals in [W]. * * @return the Channel */ default WriteChannel<Integer> getSetActivePowerEquals() { return this.channel(ChannelId.SET_ACTIVE_POWER_EQUALS); }
This approach is useful for users of Components that implement this Natures, as they get access to all the metadata of the Channel, like current value, last values, unit, description, helper methods,… - but it also adds a lot of complexity. From my experince in most cases a user would prefer simple Getter and Setter methods, like:
default int getActivePower() throws InvalidValueException { Channel<Integer> activePowerChannel = this.channel(ChannelId.ACTIVE_POWER); return activePowerChannel.value().getOrError(); } default void setActivePowerEquals(int value) throws OpenemsNamedException { WriteChannel<Integer> setActivePowerEqualsChannel = this.channel(ChannelId.SET_ACTIVE_POWER_EQUALS); setActivePowerEqualsChannel.setNextWriteValue(value); }
Alternatively for the Getter, it might be feasible to return the Value-Object. This still allows access to a subset of helper methods like
.orElse(...)
and does not throw an Exception.default Value<Integer> getActivePower() { Channel<Integer> activePowerChannel = this.channel(ChannelId.ACTIVE_POWER); return activePowerChannel.value(); }
Optionally we could still provide access to the Channels for cases where the user needs it, like:
default Channel<Integer> getActivePowerChannel() { return this.channel(ChannelId.ACTIVE_POWER); }
This change will required touching a lot of files in the source code and will cause incompatibilities with forked repositories or non-open-source OpenEMS bundles.
What is your opinion?
