Purpose of Sum.EnergyValuesHandler
Hi all,
I recently stumbled across the EnergyValuesHandler in the Sum-Component. According to the Javadoc. it is supposed to make sure that energy values are steadily rising. However, I don’t think it is doing that. Have a look at the main method:
	 * Sets the value of the Channel if it is greater-or-equals the lastValue.
	 * @param channelId the Channel-Id
	 * @param value     the energy value
	 * @return the value that was set; might be null
	public Long setValue(Sum.ChannelId channelId, Long value) {
		if (!this.lastEnergyValues.containsKey(channelId)) {
			// lastValue was not initialized yet -> ignore value
			value = null;
		} else if (value == null) {
			// if value is null, replace it by last value
			var lastValue = this.lastEnergyValues.get(channelId);
			value = lastValue;
		this.parent.channel(channelId).setNextValue(value);
		this.lastEnergyValues.put(channelId, value);
		return value;
Nowhere in the code it is checked whether value is greater or equals to the last value of the channel. All this method does is to wait for initialisation by the Timedata (first if-clause), and using the last value from the Timedata if value == null. And indeed we have seen that e.g. if a grid meter is exchanged and the new grid meter starts counting at 0 again, the values of _sum/GridBuyActiveEnergy and _sum/GridSellActiveEnergy will decrease, leading to wrong energy values in the UI-history (for the whole year actually).
I know it would be a big change, but wouldn’t it make more sense to calculate the energy values of the Sum component with CalculateEnergyFromPower, e.g. calculate _sum/GridBuyActiveEnergy and _sum/GridSellActiveEnergy from _sum/GridActivePower? It is a well established way in OpenEMS, and I think it would solve a lot of problems regarding hardware exchanges. Or am I missing something?
Let me know what you think.
Best regards,
It would indeed be a big change, but actually something we should consider… In theory calculating energy manually from power has its downsides; but the benefits might be worth it.
Hi Stefan, thanks for the response. I didn’t have time to pursue this further, but I still believe we should handle it the way I suggested. When I find time, I can implement and test it.
Can you specify the downsides of this approach?
Best regards,
Currently the Sum Energy Values are based directly on the Energy Values of the individual Meters. If we calculate Energy in Sum from Power values, we lose this relation.
This direct relation also comes with the downside that if one Meter disappears, its energy value is also missing, which might lead to negative energy. This problem would be solved if we would follow your suggestion.
