Question About Sequential ESS Operation Using ESS Cluster
Hello OpenEMS Community,
I am working on an EMS project for my master thesis using OpenEMS with two ESS modules (ess0 and ess1).
My project requirement is:
  1. ess1 should discharge first (discharge priority)
  2. ess0 should charge first (charge priority)
  3. Only one ESS should discharge at a time
  4. Both ESS modules should not share discharge power simultaneously
  5. When ess1 reaches reserve SoC, ess0 should start discharging
I currently use:
  • ESS Cluster
  • Shared grid meter
  • CSV Direct simulation for load and production
  • ESS power strategy: OPTIMIZE_BY_MOVING_TOWARDS_TARGET
However, from the logs I observe behavior like:
  • initially ess1 discharges,
  • then both ESS modules share power,
  • later ess0 becomes dominant.
This seems to behave more like a virtual aggregated battery, which is not aligned with my requirement.
Is there any way to configure ESS Cluster for:
  • discharge/charge priority,
  • preventing simultaneous discharge,
  • sequential ESS operation?
I would appreciate any suggestions or recommended architecture for implementing this behavior in OpenEMS.
Thank you.
I am also working on EMS for BESS based out of Gujarat. You can reach out to me at shilpan@urjapod.com. We can help each other out.
Thanks
Hi @kamblenidhi08 and sorry for late reply.
The feature you are looking for is not built-in yet. By design this should also not be a part of the ESS-Cluster, but a new “strategy” instead. Have a look at power distribution v2 - you should be able to adjust the logic to suit your requirement: openems/io.openems.edge.ess.core/src/io/openems/edge/ess/core/power/v2/TreeSolver.java at develop · OpenEMS/openems · GitHub
