Release 2025.11.0 · OpenEMS/openems
The changelog on github mentions
UI: Add Weather Widget in Live-View
  • Add Weather Widget
    • Added new Weather Widget in Live View below the Energy Monitor
    • Displays current weather, 6-hour forecast, and daily forecast for the next 6 days
    • Shows temperature, general weather condition, and sun hours
    • Weather data is retrieved from the Edge using coordinates stored in Meta configuration
    • Forecasts are retrieved in quarter-hourly, hourly, and daily resolution for the next 7 days
    • Linear prediction model adapted to handle the new weather data format
    • Forecasts are cached on the Edge and the UI fetches only the data it currently needs
l have added the coordinates in the _meta component, and also the Weather Open-Meteo widget is enabled. Still I do not see the UI weather widget. What am I missing?
Hi @sjjh,
try again with latest develop Branch. There were still some parts missing in the FEMS Backport.
Thanks for your update, works now! :slight_smile:
@stefan.feilmeier do i understand correctly, that the latest Backports removed Grid Surplus for EVSE and P40 ?
@Sn0w3y No, that’s not true. Why do you think so?
In commit 23db377819, the AUTOMATIC_SWITCHING mode was removed from the PhaseSwitching enum (it only has DISABLE, FORCE_SINGLE_PHASE, FORCE_THREE_PHASE now).
How is the P40 supposed to automatically switch between single-phase and three-phase charging based on available grid surplus power?
With only the forced modes available, it seems like phase-switching would need to be triggered externally (via UI or another Controller), rather than automatically responding to surplus power changes. Is that the intended behavior, or am I missing something in how the new implementation works?
Thanks for clarifying!
For now this is the intended behaviour. This is the first release that actually supports phase-switching (I use it at home with P30 + S10; tested in lab with P40; will implement with HardyBarth very soon) and we use it to gain experience.
For future we plan to have again a possibility to choose between AUTOMATIC, FORCE_SINGLE and FORCE_THREE.
Yes. That is a valid use-case for many systems.
By the way there are more use-cases for automatic switching than just "PV-Surplus”, e.g. “Switch to THREE_PHASE when in FORCE_CHARGE mode, e.g. when charging in cheapest hour)”. Also there are many vehicles that do not support phase-switching and will stop charging completely. This we will have to take care of carefully.
