Release 2025.4.0 · OpenEMS/openems
Hi @stefan.feilmeier,
I’m experiencing a problem with the UI in the new 2025.4.0 release. When starting the app, I’m getting the following error:
NullInjectorError: R3InjectorError(AppModule)[ApplicationInitStatus -> InjectionToken Application Initializer -> [object Object] -> NavigationService -> NavigationService]:
  NullInjectorError: No provider for NavigationService!
    at NullInjector.get (core.mjs:1621:27)
    at R3Injector.get (core.mjs:2148:33)
    at injectInjectorOnly (core.mjs:1116:32)
    at ɵɵinject (core.mjs:1122:60)
    at injectArgs (core.mjs:1253:23)
    at Object.factory (core.mjs:2374:52)
    at core.mjs:2271:47
    at runInInjectorProfilerContext (core.mjs:877:9)
    at R3Injector.hydrate (core.mjs:2270:21)
It seems Angular’s dependency injection system isn’t finding a provider for NavigationService. This might be due to the new version not registering the service correctly (for example, via providedIn: 'root' or in the module’s providers array), which then causes the APP_INITIALIZER to fail during bootstrapping.
Could the recent changes have inadvertently removed or misconfigured the provider for NavigationService? Any insights on whether this is an oversight or if there’s a new pattern for handling this dependency would be greatly appreciated.
Thanks!
Hi all, thanks for the update!
I updated to FEMS 2025.4.1 and it seems that the Modbus entities that I use for the Home Assistant Integration do not work anymore. Did you make any changes on Modbus?
yes we all know about these Issues right now…
Ok, thanks for the info
this issue was most likely caused by bumping capacitor versions, im on it.
Hallo Lukas,
ich vermute, dass hier eine zirkuläre Abhängigkeit im Angular DI-System die Ursache ist – wahrscheinlich wird eine bisher unerkannte Abhängigkeit durch das Capacitor-Upgrade sichtbar. Zwei Ansätze können helfen:
Ansatz 1: Anpassung in app.module.ts
Trage den NavigationService explizit in das Provider-Array ein und entferne ihn aus den APP_INITIALIZER-Abhängigkeiten:
@NgModule({
  // ...andere Moduleinstellungen
  providers: [
    // weitere Provider
    NavigationService, // Hier eintragen
      provide: APP_INITIALIZER,
      useFactory: initializeService,
      deps: [UserService], // NavigationService hier entfernen
      multi: true,
Ansatz 2: Verwendung von providedIn: ‘root’
Alternativ kannst du den NavigationService in der Service-Datei so anpassen, dass er global (auf Root-Ebene) verfügbar ist:
// In navigation.service.ts
import { Injectable, WritableSignal, signal, effect } from "@angular/core";
// weitere Importe
@Injectable({ providedIn: 'root' })  // Statt @Directive()
export class NavigationService {
  // bisherige Implementierung
There is more discussion here:
Ein kurzes Update von meiner Seite: das De-installieren der Modbus-App hat funktioniert; sie hat sich nach kurzer Zeit selbst wieder installiert, und danach kamen die Modbus-Werte wieder in HA an. Alles gut :ok_hand:
I have tried the following steps:
java -version
openjdk version “21.0.6” 2025-01-21 LTS
OpenJDK Runtime Environment Temurin-21.0.6+7 (build 21.0.6+7-LTS)
OpenJDK 64-Bit Server VM Temurin-21.0.6+7 (build 21.0.6+7-LTS, mixed mode, sharing)
java -jar openems-edge.jar
2025-04-03T13:19:33,011 [ogging])] INFO [ventAdminConfigurationNotifier] Sending Event Admin notification (configuration successful) to org/ops4j/pax/logging/Configuration
2025-04-03T13:19:33,023 [artLevel] INFO [enems.edge.application.EdgeApp] OpenEMS version [2025.4.0] started
I get an exception:
2025-04-03T13:19:41,444 [tchQueue] ERROR [Events.Framework ] FrameworkEvent ERROR
org.osgi.framework.ServiceException: Service factory exception: Could not obtain lock
at org.apache.felix.framework.ServiceRegistrationImpl.getFactoryUnchecked(ServiceRegistrationImpl.java:354) ~[?:?]
at org.apache.felix.framework.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:249) ~[?:?]
at org.apache.felix.framework.ServiceRegistry.getService(ServiceRegistry.java:362) ~[?:?]
at org.apache.felix.framework.Felix.getService(Felix.java:3984) ~[?:?]
at org.apache.felix.framework.BundleContextImpl.getService(BundleContextImpl.java:450) ~[?:?]
at io.openems.edge.core.componentmanager.ComponentManagerImpl.getComponentsViaService(ComponentManagerImpl.java:242) ~[?:?]
at io.openems.edge.core.componentmanager.ComponentManagerImpl.getComponentsViaService(ComponentManagerImpl.java:219) ~[?:?]
at io.openems.edge.core.componentmanager.ComponentManagerImpl.getEnabledComponents(ComponentManagerImpl.java:178) ~[?:?]
at io.openems.edge.core.componentmanager.OsgiValidateWorker.findDefectiveComponents(OsgiValidateWorker.java:99) ~[?:?]
at io.openems.edge.core.componentmanager.OsgiValidateWorker.forever(OsgiValidateWorker.java:80) ~[?:?]
at io.openems.common.worker.AbstractWorker$1.run(AbstractWorker.java:155) ~[?:?]
Caused by: java.lang.IllegalStateException: Could not obtain lock
at org.apache.felix.scr.impl.manager.AbstractComponentManager.obtainLock(AbstractComponentManager.java:242) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.obtainStateLock(AbstractComponentManager.java:289) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:908) ~[?:?]
at org.apache.felix.framework.ServiceRegistrationImpl.getFactoryUnchecked(ServiceRegistrationImpl.java:349) ~[?:?]
… 10 more
2025-04-03T13:19:46,477 [tchQueue] ERROR [Events.Framework ] FrameworkEvent ERROR
at io.openems.edge.core.componentmanager.ComponentManagerImpl.getAllComponents(ComponentManagerImpl.java:188) ~[?:?]
at io.openems.edge.core.componentmanager.EdgeConfigWorker.getChannels(EdgeConfigWorker.java:188) ~[?:?]
at io.openems.edge.core.componentmanager.EdgeConfigWorker.readConfigurations(EdgeConfigWorker.java:324) ~[?:?]
at io.openems.edge.core.componentmanager.EdgeConfigWorker.buildNewEdgeConfig(EdgeConfigWorker.java:151) ~[?:?]
at io.openems.edge.core.componentmanager.EdgeConfigWorker.getEdgeConfig(EdgeConfigWorker.java:99) ~[?:?]
at io.openems.edge.core.componentmanager.EdgeConfigWorker.forever(EdgeConfigWorker.java:73) ~[?:?]
… 13 more
But it seems running, I have checked the Apache website:
http://localhost:8080/system/console/status-System%20Properties
native.encoding = Cp1250
openems.data.dir = c:/openems/data
org.apache.felix.eventadmin.Timeout = 0
org.ops4j.pax.logging.DefaultServiceLog.level = INFO
org.osgi.framework.startlevel.beginning = 18
org.osgi.service.http.port = 8080
I have downloaded the UI 2025.4 version and I have tried to run from Visual Sudio Code.
I have modified the edge-dev.ts file:
url: getWebsocketScheme() + location.hostname + “:8080”,
ng serve -c openems-edge-dev
Build at: 2025-04-03T11:13:56.893Z - Hash: 1e79e5caa00f0f24 - Time: 177075ms
** Angular Live Development Server is listening on localhost:4200, open your browser on http://localhost:4200/ **
In the browser there is just a blank page no login screen, nothing.
May I get some suggestions what am I doing wrong?
Thanks in advance!
Gabor
I have downloaded the latest docker image and the blank page nothing else.
openems_docker
I also tried the gitpod, same result :frowning:
Gabor
This is what I see in the browser:
Thanks for reporting. This specific error should be fixed now on develop branch:
It seems working now, thanks! :smiley:
Best regards,
Gabor
