Hello openEMS Community,
I am working on a project where I need to run openEMS ui on a Raspberry Pi to build an HMI. However, I am encountering some issues related to the hardware, particularly with memory limitations.
Any advice or suggestions on how to resolve this would be greatly appreciated.
Thank you!
Hi and welcome to the OpenEMS Community.
So you are running OpenEMS Edge and OpenEMS UI on that Raspberry Pi? What’s the issue? Do you see any error message?
Hello @stefan.feilmeier,
Thank you for your response. I resolved the problem using two approaches:
- Serving the UI using Nginx or deploying it with Docker.
But, I decided to work with the openems_backend
, backend-ui
, and metadata
Thanks again for your guidance!
Best regards,
