Hallo nochmal miteinander
Habe den Code nun soweit fertig, aber ich sehe in der UI keine Volt und Ampere Werte ?
package io.openems.edge.io.shelly.shellyplus1pm;
import java.util.Objects;
import org.osgi.service.component.ComponentContext;
import org.osgi.service.component.annotations.ReferenceScope;
import org.osgi.service.event.Event;
import org.osgi.service.event.EventHandler;
import org.osgi.service.event.propertytypes.EventTopics;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
import com.google.gson.JsonElement;
import com.google.gson.JsonObject;
import io.openems.edge.bridge.http.api.BridgeHttp;
import io.openems.edge.common.channel.BooleanWriteChannel;
import io.openems.edge.common.channel.value.Value;
import io.openems.edge.common.component.AbstractOpenemsComponent;
import io.openems.edge.common.event.EdgeEventConstants;
import io.openems.edge.io.api.DigitalOutput;
import io.openems.edge.meter.api.ElectricityMeter;
import io.openems.edge.meter.api.MeterType;
import io.openems.edge.meter.api.SinglePhase;
import io.openems.edge.meter.api.SinglePhaseMeter;
@Component(//
name = "IO.Shelly.Plus1PM", //
immediate = true, //
configurationPolicy = ConfigurationPolicy.REQUIRE//
@EventTopics({ //
EdgeEventConstants.TOPIC_CYCLE_EXECUTE_WRITE //
public class IoShellyPlus1PMImpl extends AbstractOpenemsComponent
implements IoShellyPlus1PM, DigitalOutput, SinglePhaseMeter, ElectricityMeter, OpenemsComponent, EventHandler {
private final Logger log = LoggerFactory.getLogger(IoShellyPlus1PMImpl.class);
private final BooleanWriteChannel[] digitalOutputChannels;
private MeterType meterType = null;
private SinglePhase phase = null;
private String baseUrl;
@Reference(scope = ReferenceScope.PROTOTYPE_REQUIRED)
private BridgeHttp httpBridge;
public IoShellyPlus1PMImpl() {
super(//
ElectricityMeter.ChannelId.values(), //
DigitalOutput.ChannelId.values(), //
IoShellyPlus1PM.ChannelId.values() //
this.digitalOutputChannels = new BooleanWriteChannel[] { //
this.channel(IoShellyPlus1PM.ChannelId.RELAY) //
SinglePhaseMeter.calculateSinglePhaseFromActivePower(this);
@Activate
private void activate(ComponentContext context, Config config) {
super.activate(context, config.id(), config.alias(), config.enabled());
this.meterType = config.type();
this.phase = config.phase();
this.baseUrl = "http://" + config.ip();
if (!this.isEnabled()) {
return;
this.httpBridge.subscribeJsonEveryCycle(this.baseUrl + "/rpc/Shelly.GetStatus", this::processHttpResult);
@Override
@Deactivate
protected void deactivate() {
super.deactivate();
@Override
public BooleanWriteChannel[] digitalOutputChannels() {
return this.digitalOutputChannels;
@Override
public String debugLog() {
var b = new StringBuilder();
var valueOpt = this.getRelayChannel().value().asOptional();
if (valueOpt.isPresent()) {
b.append(valueOpt.get() ? "ON" : "OFF");
} else {
b.append("Unknown");
b.append("|");
b.append(this.getActivePowerChannel().value().asString());
// Debugging voltage
Value<Integer> voltage = this.getVoltageL1();
b.append("|");
b.append("V: " + voltage);
Value<Integer> current = this.getCurrentL1();
b.append("|");
b.append("A: " + current);
return b.toString();
@Override
public void handleEvent(Event event) {
return;
switch (event.getTopic()) {
case EdgeEventConstants.TOPIC_CYCLE_EXECUTE_WRITE -> {
this.executeWrite(this.getRelayChannel(), 0);
private void processHttpResult(JsonElement result, Throwable error) {
this._setSlaveCommunicationFailed(result == null);
if (error != null) {
this._setRelay(null);
this._setActivePower(null);
this._setActiveProductionEnergy(null);
this.logDebug(this.log, error.getMessage());
return;
try {
JsonObject jsonResponse = result.getAsJsonObject();
// Extracting data from "switch:0"
JsonObject switch0 = jsonResponse.getAsJsonObject("switch:0");
if (switch0 != null) {
boolean relayIson = switch0.get("output").getAsBoolean();
Integer power = (int) switch0.get("apower").getAsFloat();
Integer voltage = (int) switch0.get("voltage").getAsFloat(); // Reading voltage
Integer current = (int) switch0.get("current").getAsFloat(); // Reading voltage
JsonObject aenergy = switch0.getAsJsonObject("aenergy");
long energy = aenergy != null ? aenergy.get("total").getAsLong() : 0;
// Processing the extracted data
this._setRelay(relayIson);
this._setActiveProductionEnergy(energy / 60);
setValuesForInverter(voltage, current, power);
} catch (Exception e) {
this.logDebug(this.log, e.getMessage());
private void setValuesForInverter(Integer voltage, Integer current, Integer power) {
// Check the configured phase and set values accordingly
if (this.phase != null) {
switch (this.phase) {
case L1:
this._setActivePowerL1(power);
this._setVoltageL1(voltage * 1000);
this._setCurrentL1(current * 1000);
this._setVoltageL2(0);
this._setCurrentL2(0);
this._setVoltageL3(0);
this._setCurrentL3(0);
break;
case L2:
this._setActivePowerL2(power);
this._setVoltageL2(voltage * 1000);
this._setCurrentL2(current * 1000);
this._setVoltageL1(0);
this._setCurrentL1(0);
break;
case L3:
this._setActivePowerL3(power);
this._setVoltageL3(voltage * 1000);
this._setCurrentL3(current * 1000);
break;
this._setCurrent(current * 1000);
this._setVoltage(voltage * 1000);
this._setActivePower(power);
* Execute on Cycle Event "Execute Write".
* @param channel write channel
* @param index index
private void executeWrite(BooleanWriteChannel channel, int index) {
var readValue = channel.value().get();
var writeValue = channel.getNextWriteValueAndReset();
if (writeValue.isEmpty()) {
// no write value
return;
if (Objects.equals(readValue, writeValue.get())) {
// read value = write value
return;
final var url = this.baseUrl + "/relay/" + index + "?turn=" + (writeValue.get() ? "on" : "off");
this.httpBridge.request(url).whenComplete((t, e) -> {
this._setSlaveCommunicationFailed(e != null);
@Override
public MeterType getMeterType() {
return this.meterType;
@Override
public SinglePhase getPhase() {
return this.phase;
im Log sehe ich aber:
Die UI bleibt aber leider leer
Unter den Channel’s in den Settings sehe ich die richtigen Werte auch - an was könnte das liegen?
