Hello together ![]()
I made a simple Python Script which helps Devs to “Simulate” and Test for example SImple Json Answers or Devices in OpenEMS ![]()
Feel free to improve or use it ! ![]()
from flask import Flask, jsonify, request
import json
app = Flask(__name__)
# Configuration Variables
JSON_FILE_PATH = 'json_file.json' # Path to your JSON file
SERVER_PORT = 80 # Server port
SERVER_HOST = '0.0.0.0' # Server host, use '0.0.0.0' to make server accessible externally
ENDPOINT = '/status' # Endpoint to serve JSON data
# Load our JSON data from a file
def load_json_data():
with open(JSON_FILE_PATH, 'r') as file:
data = json.load(file)
return data
# Set up the endpoint to serve the JSON data
@app.route(ENDPOINT, methods=['GET'])
def get_data():
data = load_json_data()
# Check if 'id' parameter is present in the query string
query_id = request.args.get('id')
if query_id:
filtered_data = {key: value for key, value in data.items() if key == query_id}
return jsonify(filtered_data)
# If no 'id' parameter is specified, return all data
return jsonify(data)
if __name__ == '__main__':
app.run(debug=True, host=SERVER_HOST, port=SERVER_PORT)
