SolarEdge HybridWechselrichter mit Batterie steuern
Hallo Lóránt,
super Timing…gerade heute habe ich etwas daran experimentiert. Das Schreiben der Register funktioniert.
Meine applyPower-Methode sieht so aus:
	public void applyPower(int activePowerWanted, int reactivePowerWanted) throws OpenemsNamedException {
		CycleCounter++;
		// Read-only mode -> switch to max. self consumption automatic
		if (this.config.readOnlyMode() ) {
			if ( CycleCounter > 60) {
				CycleCounter=0;
				// Switch to automatic mode
				EnumWriteChannel setControlModeChannel = this.channel(SolarEdgeHybridEss.ChannelId.SET_CONTROL_MODE);
				setControlModeChannel.setNextWriteValue(ControlMode.SE_CTRL_MODE_MAX_SELF_CONSUMPTION);
				// The next 2 are fallback values which should become active after the 60 seonds timeout
				EnumWriteChannel setChargeDischargeDefaultMode	= this.channel(SolarEdgeHybridEss.ChannelId.SET_CHARGE_DISCHARGE_DEFAULT_MODE); //Same enum as Remote control mode
				setChargeDischargeDefaultMode.setNextWriteValue(ChargeDischargeMode.SE_CHARGE_POLICY_MAX_SELF_CONSUMPTION);	// This mode is active after remote control timeout exceeded
				IntegerWriteChannel setCommandTimeout		= this.channel(SolarEdgeHybridEss.ChannelId.SET_REMOTE_CONTROL_TIMEOUT);
				setCommandTimeout.setNextWriteValue(60); // Our Remote-commands are only valid for a minute
				setLimits();
			return;
		else {
			if (CycleCounter > 0) { // Set values every Cycle
				CycleCounter=0;
				//read_only is NOT enabled
				EnumWriteChannel setControlMode 				= this.channel(SolarEdgeHybridEss.ChannelId.SET_CONTROL_MODE);
				EnumWriteChannel setChargePolicy 				= this.channel(SolarEdgeHybridEss.ChannelId.SET_STORAGE_CHARGE_POLICY);
				EnumWriteChannel setChargeDischargeMode			= this.channel(SolarEdgeHybridEss.ChannelId.SET_REMOTE_CONTROL_COMMAND_MODE);	//Same enum as Remote control default mode
				IntegerWriteChannel setChargePowerLimit		= this.channel(SolarEdgeHybridEss.ChannelId.SET_MAX_CHARGE_POWER);
				IntegerWriteChannel setDischargePowerLimit	= this.channel(SolarEdgeHybridEss.ChannelId.SET_MAX_DISCHARGE_POWER);
				if (isControlModeRemote() == false)
					setControlMode.setNextWriteValue(ControlMode.SE_CTRL_MODE_REMOTE);	// Now the device can be remote controlled
					setChargePolicy.setNextWriteValue(AcChargePolicy.SE_CHARGE_DISCHARGE_MODE_ALWAYS);	// Always allowed.When used with Maximize self-consumption, only excess power is used for charging (charging from the grid is not allowed)
	//			setControlMode.setNextWriteValue(ControlMode.SE_CTRL_MODE_REMOTE);	// Now the device can be remote controlled
	//			setChargePolicy.setNextWriteValue(AcChargePolicy.SE_CHARGE_DISCHARGE_MODE_ALWAYS);	// Always allowed.When used with Maximize self-consumption, only excess power is used for charging (charging from the grid is not allowed)
				if (activePowerWanted <= 0) { // Negative Values are for charging
					setChargeDischargeMode.setNextWriteValue(ChargeDischargeMode.SE_CHARGE_POLICY_PV_AC); // Mode for charging
					setChargePowerLimit.setNextWriteValue(activePowerWanted * -1); // Values for register must be positive
				else {
					setChargeDischargeMode.setNextWriteValue(ChargeDischargeMode.SE_CHARGE_POLICY_MAX_EXPORT); // Mode for discharging
					setDischargePowerLimit.setNextWriteValue(activePowerWanted);
Der Modbus-Task schreibt alle Register auf Einmal:
		protocol.addTask(//
		new FC16WriteRegistersTask(0xE004,
				m(SolarEdgeHybridEss.ChannelId.SET_CONTROL_MODE, new SignedWordElement(0xE004)),
				m(SolarEdgeHybridEss.ChannelId.SET_STORAGE_CHARGE_POLICY, new SignedWordElement(0xE005)), // Max. charge power. Negative values
				m(SolarEdgeHybridEss.ChannelId.SET_MAX_CHARGE_LIMIT, new FloatDoublewordElement(0xE006).wordOrder(WordOrder.LSWMSW)),  // kWh or percent
				m(SolarEdgeHybridEss.ChannelId.SET_STORAGE_BACKUP_LIMIT, new FloatDoublewordElement(0xE008).wordOrder(WordOrder.LSWMSW)),  // Percent of capacity
				m(SolarEdgeHybridEss.ChannelId.SET_CHARGE_DISCHARGE_DEFAULT_MODE, new UnsignedWordElement(0xE00A)), // Usually set to 1 (Charge PV excess only)
				m(SolarEdgeHybridEss.ChannelId.SET_REMOTE_CONTROL_TIMEOUT, new UnsignedDoublewordElement(0xE00B).wordOrder(WordOrder.LSWMSW)),
				m(SolarEdgeHybridEss.ChannelId.SET_REMOTE_CONTROL_COMMAND_MODE, new UnsignedWordElement(0xE00D)),
				m(SolarEdgeHybridEss.ChannelId.SET_MAX_CHARGE_POWER, new FloatDoublewordElement(0xE00E).wordOrder(WordOrder.LSWMSW)),  // Max. charge power. Negative values
				m(SolarEdgeHybridEss.ChannelId.SET_MAX_DISCHARGE_POWER, new FloatDoublewordElement(0xE010).wordOrder(WordOrder.LSWMSW)) // Max. discharge power. Positive values
				)); // Disabled, automatic, remote controlled, etc.
Kommentare und Programmierstil sind noch nicht so richtig schick…
Ich habe versuchsweise mal den Balancing-Controller für optimierten Eigenverbrauch aktiviert. Fehler beim Modbus-Write bekomme ich zwar nicht, aber die Anlage “überregelt” ziemlich heftig. Die Cycle-Time ist bei 1 Sekunde.
Auf GitHib ist der Code noch nicht - kommt in den nächsten Tagen…
Klinki
