Is the family of SolaX inverters somehow supported already (maybe under different name…)? They become really common in household installations last year.
Thanks,
Jiri
Thanks,
Jiri
Hi Jiri,
I do not know of any compatible integration in OpenEMS. There are lots of PV-inverters and Battery-inverters coming newly to the market…
Usually reading data from a PV-inverter is easily done; sometimes even via SunSpec, but most often it’s a matter of simply writing down the most important registers of a Modbus table. (see the Implementing a device :: Open Energy Management System guide).
Battery-inverters typically require a lot more programming and testing.
I just need the Modbus Registers and i would try to implement it myself
Does somebody have these?
Greetings!
