ich poste hier mal die currentData edgeRPC:
Wie hier zu sehen ist, ist der Status überall 0 wenn es IO ist… an was kann das liegen?
Lokal auf meinem Rechner von Simulator Edge zu Dev UI gehts. Nur in der Backend UI wird es als “null” angezeigt.
Danke für eure Hilfe !
"jsonrpc": "2.0",
"method": "edgeRpc",
"params": {
"edgeId": "EMS2",
"payload": {
"jsonrpc": "2.0",
"method": "currentData",
"params": {
"charger0/ActualPower": 3974,
"charger1/ActualPower": 4173,
"ctrlIoHeatPump2/State": 0,
"ctrlIoHeatPump2/Status": null,
"ctrlIoHeatPump2/_PropertyMode": null,
"ctrlIoHeatingElement0/ForceStartAtSecondsOfDay": null,
"ctrlIoHeatingElement0/Status": null,
"ctrlIoHeatingElement0/_PropertyMode": null,
"ctrlIoHeatingElement0/_PropertyWorkMode": null,
"ess0/Capacity": 20000,
"ess0/DcDischargePower": -122,
"ess0/Soc": 100,
"io0/Relay3": null,
"io0/Relay4": null,
"io0/Relay5": null,
"io1/ActivePower": 580,
"io2/Relay": null,
"meter2/ActivePower": 88,
"meter2/ActivePowerL1": 40,
"meter2/ActivePowerL2": 21,
"meter2/ActivePowerL3": 27,
"temp0/Temperature": null,
"_sum/ConsumptionActivePower": 6307,
"_sum/ConsumptionActivePowerL1": 189,
"_sum/ConsumptionActivePowerL2": 42,
"_sum/ConsumptionActivePowerL3": 6075,
"_sum/ConsumptionMaxActivePower": 11400,
"_sum/EssActivePower": 8026,
"_sum/EssActivePowerL1": 2675,
"_sum/EssActivePowerL2": 2675,
"_sum/EssActivePowerL3": 2675,
"_sum/EssMaxApparentPower": 10000,
"_sum/EssSoc": 100,
"_sum/GridActivePower": -2299,
"_sum/GridActivePowerL1": -3066,
"_sum/GridActivePowerL2": -2633,
"_sum/GridActivePowerL3": 3400,
"_sum/GridMaxActivePower": 800,
"_sum/GridMinActivePower": -5400,
"_sum/GridMode": 1,
"_sum/ProductionAcActivePower": 580,
"_sum/ProductionActivePower": 8727,
"_sum/ProductionDcActualPower": 8147,
"_sum/ProductionMaxActivePower": 9000
