is it possible to configure more than one DB in the Backend?
If yes (I saw it would work) how woul OpenEMS handle this then?
Right now i implemented a secondary aggregated0 in the Config and the Code writes the data once in the main DB and in the secondary DB duplicationable.
package io.openems.backend.timedata.aggregatedinflux;
import org.osgi.service.metatype.annotations.AttributeDefinition;
import org.osgi.service.metatype.annotations.ObjectClassDefinition;
import io.openems.shared.influxdb.QueryLanguageConfig;
@ObjectClassDefinition(//
name = "Timedata.AggregatedInfluxDB", //
description = "Configures the InfluxDB timedata provider" //
@interface Config {
@AttributeDefinition(name = "Component-ID", description = "Unique ID of this Component")
String id() default "timedata0";
@AttributeDefinition(name = "Query language", description = "Query language Flux or InfluxQL")
QueryLanguageConfig queryLanguage() default QueryLanguageConfig.INFLUX_QL;
@AttributeDefinition(name = "URL", description = "The primary InfluxDB URL, e.g.: http://ip:port")
String url();
@AttributeDefinition(name = "Org", description = "The Organisation; '-' for InfluxDB v1")
String org() default "-";
@AttributeDefinition(name = "ApiKey", description = "The ApiKey; 'username:password' for InfluxDB v1")
String apiKey();
@AttributeDefinition(name = "Bucket", description = "The bucket name; 'database' for InfluxDB v1")
String bucket();
@AttributeDefinition(name = "Retention policy name for average values", description = "The retention policy name for InfluxDB v1 for daily values")
String retentionPolicyAvg() default "rp_avg";
@AttributeDefinition(name = "Retention policy name for max values", description = "The retention policy name for InfluxDB v1 for monthly values")
String retentionPolicyMax() default "rp_max";
@AttributeDefinition(name = "Measurement avg", description = "The InfluxDB measurement for average values")
String measurementAvg() default "avg";
@AttributeDefinition(name = "Measurements for max values", description = "Measurements for max values for each timezone. Format: \"(timezone)=(measurement)\"")
String[] measurementsMax() default { "Europe/Berlin=max" };
@AttributeDefinition(name = "Read-Only mode", description = "Activates the read-only mode. Then no data is written to InfluxDB.")
boolean isReadOnly() default false;
@AttributeDefinition(name = "Number of Threads", description = "Pool-Size: the number of threads dedicated to handle the tasks")
int poolSize() default 10;
@AttributeDefinition(name = "Number of max scheduled tasks", description = "Max-Size of Queued tasks.")
int maxQueueSize() default 5000;
@AttributeDefinition(name = "Secondary URL", description = "The secondary InfluxDB URL, write-only for security and fallback purposes, e.g.: http://ip:port")
String secondaryUrl();
@AttributeDefinition(name = "Secondary Org", description = "The secondary Organisation; '-' for InfluxDB v1")
String secondaryOrg() default "-";
@AttributeDefinition(name = "Secondary ApiKey", description = "The secondary ApiKey; 'username:password' for InfluxDB v1")
String secondaryApiKey();
@AttributeDefinition(name = "Secondary Bucket", description = "The secondary bucket name; 'database' for InfluxDB v1")
String secondaryBucket();
@AttributeDefinition(name = "Secondary InfluxDB Information", description = "Information about the secondary InfluxDB. The secondary database is write-only and serves as a fallback for security reasons in case the primary one fails.")
String secondaryDbInfo() default "The secondary InfluxDB is write-only and serves as a fallback for security reasons.";
String webconsole_configurationFactory_nameHint() default "Timedata Aggregated InfluxDB";
The code handles it like this then:
// Initialize the secondary connector if provided in the config
if (!config.secondaryUrl().isEmpty() && !config.secondaryApiKey().isEmpty()
&& !config.secondaryBucket().isEmpty()) {
this.secondaryInfluxConnector = new InfluxConnector(config.id() + "-secondary", config.queryLanguage(),
URI.create(config.secondaryUrl()), config.secondaryOrg(), config.secondaryApiKey(),
config.secondaryBucket(), this.oem.getInfluxdbTag(), config.isReadOnly(), config.poolSize(),
config.maxQueueSize(), throwable -> {
this.logError(this.log, "Unable to write to secondary InfluxDB. "
+ throwable.getClass().getSimpleName() + ": " + throwable.getMessage());
}, true, this.writeParametersAvgPoints, this.writeParametersMaxPoints);
Greetings !
