The username and password described here are not working.
Also not the ones from the getting-started guide.
Hi Daniel,
thanks for pointing this out. There was indeed an error in the Gitpod definition, that still pointed to an old development branch in the Odoo module. It’s fixed in:
Unfortunately it seems the Odoo integration is currently still broken and I am not able to fix it quickly. As a reminder for my future self, this is what I tried…
admin with password admin
edge0
WZZyzpPSMM5fE6aQ667Z (this is the default apikey given in the Gitpod docker container for OpenEMS Edge, see: openems/28628d01-a978-4328-9a8f-b9c7751ed2d2.config at develop · OpenEMS/openems · GitHub)Click Save
Back in Gitpod open the terminal for OpenEMS Backend
Press Ctrl + C to stop Backend.
Press the Arrow Up key on your keyboard to get the latest command and press Enter to execute it and restart Backend. (or copy this command java -Dfelix.cm.dir=$(pwd)/tools/docker/openems-backend/config.d -jar build/openems-backend.jar)
Unfortunately Backend fails to import the Edges from Odoo with the following error message:
[io.openems.backend.metadata.odoo.postgres.InitializeEdgesWorker] ERROR : [Metadata.Odoo] Unable to initialize Edges: PSQLException. ERROR: column "state" does not exist
Position: 46
org.postgresql.util.PSQLException: ERROR: column "state" does not exist
Internally we already switched to Odoo 14, so I suppose we need to backport our changes first… sorry for that.
I gave the Gitpod Live-Demo a complete overhaul. Live-Demo should now work with this link: (this runs the develop branch demo, because the required updates will only be released to master on 1st of June)
https://gitpod.io/#https://github.com/OpenEMS/openems/tree/develop
Updated documentation for Gitpod Live-Demo is here:
https://openems.github.io/openems.io/openems/latest/simulation/gitpod.html
