Hello folks,
I am trying to simulate my own load and PV data.
I defined the predefined data sources using these two files.
But log output shows as below:
2023-10-22T16:33:26,505 [_cycle ] INFO [ebuglog.ControllerDebugLogImpl] [ctrlDebugLog0] _sum[State:Fault Ess SoC:50 %|L:0 W Consumption:0 W] ctrlBalancing0[State:FAULT: Running the Controller failed] ess0[SoC:50 %|L:0 W|Allowed:-10000;10000 W] meter0[UNDEFINED] meter1[UNDEFINED] modbus0[CycleDelay:987 ms]
Could you please advise to solve this issue?
Thanks
Regards
The information you provide is not sufficient to find the error. What I can see is that the meters don’t have active power values, and I assume the controller balancing uses either of them and therefore running it fails. Are the meters supposed to get the data from your datasources? If so, check the following:
- Do the files
load-archive.csv and pv-archive.csv look like they’re supposed to look lijke?
- Are they in the right directory?
Best regards,
Thank you very much @tsicking. I have checked two files are in the right directory, but I ingested three months of data, and it raised the above errors. Now I changed the data already and the results are correct.
Thanks.
Regards
Hello folks,
I have load and PV data in every 15 m time resolution and unit in KW. I found the link:
I would like to know where should I edit to be the correct active power. Although there is some explanation in the above link, I don’t get it yet.
Could anyone suggest?
Thank you in advance.
